Why won't the 233 engine handle AC, I've read this on many web sites but it never said why.Because it has not enough power or there is no way to mount it Thanks
My 1.6L Miata has ac, but it is pokey when it's on. Still worth having though on really hot days. I shut if off if I need to accelerate hard, then turn it back on. AFA brackets, Alan Grove may make them. Worth a look.
I put A/C on the 215 in my 53 sedan using a Sanden compressor. My problem wasn't pulling power, it was the air flow restriction added by the modern hi efficiency condenser in front of the radiator. This should not be a problem with the much larger truck radiator.
