A few questions about 7.3 accesories
Hi aussie chapter.
Just bought a 2002 4x4 F250 with a 7.3 to replace my turbo 1HZ landcruiser.
I would like some info about fitting a few essential items.
Firstly how easy is installing the thermocouple for an EGT guage?
The landcruiser was easy, unscrew a plug and screw in the thermocouple.
Second, where can I get a decent snorkel?
Next, How do I identify what diffs I have in order to get the correct air lockers?
And finally for this post, are bypass oil filters worth the effort/expense?
Thanks in advance.
Thanks in advance.
Hi there Brian (we almost have too many Brians on this site)
Welcome to the site, there are some very knowledgeable people on this site to answer your questions.
I will give it a go.
1. EGT. You will have to drill a hole either in your exhaust manifold or in the up pipe going to the turbo (assuming you are installing it before the turbo). There are heaps of instruction available from the different suppliers. Try http://www.riffraffdiesel.com/mm5/RE...ISSPRO_EV2.pdf
2. Snorkel. In my opinion the only good snorkel is one that would be made out of pipe. A good friend had a safari snorkel installed, it just didn't flow enough air for the 7.3L. The reason I know this is that the spring loaded Ford Filter tell-tale device installed in the filter box would always move to the maximum limit therefore indicating that the filter is clogged or the snorkel is not flowing enough air. The filter was new.
Do you have the original style filter in there. If you do, I would replace it with a 6637 (this will give you a louder turbo whine) or the Ford AIS kit (which flows alot more air than the original)
3. Airlockers. The rear diff is a Ford 10.5 inch (airlocker part number RD170), the front diff should be a Dana 60 Reverse (airlocker part number RD167)
4. Bypass Filters. This is a personal option. I think the current opinion is if you are going to try to extend you current oil change intervals, then run a bypass filter. If you will change your oil at the recommended intervals, then just run a normal full flow filter and change it everytime.
I will soon be putting a filter on my F250 as I want to extend changes.
I think that is about it. I am sure more guys will chime it with there opinions.
Thanks
Thanks
Many thanks for the info
Kramer73,
Thanks for the info, most helpfull.
Drilling into the exhaust sounds like a bit of a PITA and I would
worry about bits of metal ending up in the turbo.
If thats the only option then I guess I'll have to bite the bullet
as I would not want to run without the EGT gauge.
The air intake is not standard, the box is gone and ther is a big
pod style filter on it.
I don't know what make it is. When I get a chance I will post a
photo and see if some one on the forum can identify it.
By a snorkel made out of pipe I assume you mean something custom
bent on a mandrel. I will have to find someone in Adelaide that could
do that work as I have niether the skill or equipment to do that kind
of work.
Thanks for the airlocker part numbers, saved much head scratching.
As for the oil filter, I am not seeking to extend intervals just want to
make sure the oil is as clean as possible as I have studied the way the
injectors are operated in the 7.3 and understand how critical the oil
system is to the operation of the engine.
I don't mind frequent oil changes, I do oil and filter every 5,000kms in
the landcruiser. As the saying goes oils is cheaper than engines.
Thanks again for the info.
of work.
You have two options regarding the EGT's. Post or Pre turbo. Drilling and tapping the manifold (pre) is more accurate and trust me, its alot easier than getting that downpipe in and out. You will need a 1/8th npt tap and 11/32 drill and the wifes vacuum to suck out any filings.
Passenger side manifold just below the arrow
Safari snorkel for me. All the majors supply em. If you live in Sydney I can put you on to a guy who can supply and fit
I totally agree about changing oil. BUT, todays oils can last alot longer than 5K. These things take around 17ltrs and 5K comes around quickly. I do run the bypass and change every 15K and I havent had a bad Oil analysis yet. Personal choice here but I went with the Oilguard set up. the kit comes with everything you need.
the two black hoses above the OEM oil filter are you supply and return lines
the unit
fitted
the unit
fitted
Brian,
Thanks for the info and photos.
I assume you drill the manifold in place, not removed
from the truck.
Correct
You have not had any air starvation problems with
the Safari I take it.
I have the aFe stage II intake, so it gets plenty of air
Is the oilguard unit available in Australia or do I need
to source it from the US?
from the truck.
Correct
FYI, I found drilling the exhaust manifold and tapping it easy. I just started with a small diameter drill bit and worked my way up to the tap size.
The only piece of info I can add is that I had a small amount of exhaust leakage through the probe threads. I cured this by applying exhaust sealant to the probe threads then re-fitting the probe.
BTW, the 'stock' Down Pipe that FA supplied to these vehicles is an EGT generator. You want to change that over ASAP. Reg on this forum had good results with a 3.5" downpipe. That's what I'd recommend as it is an easier fit than the 4" or larger DPs, but is big enough to do a much better job than the FA strangulator pipe. With the stock FA DP I used to see 850C EGT's, now it barely ever gets to 400.
All the best with it!
Thanks both of you for the info.
I will have to confirm but I believe the stock down pipe has been
replaced with a 4" unit by the previous owner.
The exhaust is a 4" aftermarket job.
The photo of the air filter looks very much like mine.
How does that seal with a snorkel?
Is there an Aussie supplier of replacement filters for the oilguard
or do they have to be sourced from the US as well?
The difference in the down pipe is noticeable. Just see if they went 4" from the downpipe back
The snorkel doesnt seal. If I was to do some serious 4wd'n I would go for something like this
Riffraff Diesel: S&B Cold Air Intake Kit - Oiled Element
Or the ford AIS
I get the filters of Clay in the States. I havent tried to see if you can get em here.. I change em every 30K so I get three at a time.
Or the ford AIS
I remember reading on the US forum that there is a problem with the OEM airbox warping with age, then the paper element not sealing properly.
This was one of the justifications for replacing the original airbox and filter.
For instance, your friend's 'like' for the original paper air filters could change drastically if he were to find evidence of dust on the wrong side of the filter.
The pod style filters are simply clamped onto the intake pipe making for a very effective & reliable air tight seal.
