Body side graphics removal? - Ford Truck Enthusiasts Forums
Old 05-24-2013, 09:35 AM
Demo-man Demo-man is offline
Demo-man is starting off with a positive reputation.
Looking at buying a raptor this weekend. Only issue is it has the body side graphics which would have to go. Anyone have any ideas on if these come off and how they did it? I assume the old hair dryer and slow pealing would work.
Much appreciated
Old 05-24-2013, 01:56 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
If you are referring to the stickers, a heat gun will soften & allow removal &/or 3M makes an excellent adhesive remover (most auto paint suppliers 7 hardware stores carry)
if you're referring to the double back tape....gently warm the tape 7 then use a fine thread to place between the emblem & the paint, gently in a saw type action, cut/lift the double back tape from the paint (you tube has vids on this)
some have barrel nuts...need to check.
Old 05-26-2013, 08:14 AM
johnday's Avatar
johnday johnday is online now
johnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to behold
When I picked up my '12, I'd already had the dealer remove the 4times4 sticker before I even saw the truck. Well, when I saw it, there was this tacky, godawful, ghost flame graphic extending from the front wheelwells, across the front doors, and ending at the back edge of the rear doors. HELL NO!!!!, were the first words out of my mouth. Get that OFF MY TRUCK!!!! They used some sort of eraser wheel, they called it. The sticker was so large that I wasn't going to attempt it, let alone it being a new truck and me chancing screwing the paint up. They told me that a lot of people commented on how good the thing looked. I almost asked if they may have been from Bangladesh or 5 years old, and watched Ice Road Truckers when they were in India.
Anyway, the wheel did a good job, but I wouldn't trust myself with it.
Like Beechkid said, a heatgun/hairdryer works well, and I've followed up with some of that 3M adhesive remover, then wax. That was on small stickers, and would likely take forever with a large graphic.
Old 08-01-2013, 11:03 PM
jswanitz's Avatar
jswanitz jswanitz is offline
jswanitz is starting off with a positive reputation.
Quote:
Much appreciated
I have also used the 3M pad on a simple drill wheel a number of times and it does the trick.
I am late to this conversation, but if you haven't done it yet, go that route.
It's a bit time consuming, but works well. Take your time and don't be overly aggressive, it will work.
Opinion on 1976 BiCentennial Model F-150 Preservation John McIntyre 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-14-2015 08:29 PM
door molding, pin stripe door handles 04badford 6.0L Power Stroke Diesel 0 11-15-2014 06:24 PM
Truck graphics Charles2703 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-11-2014 07:12 PM
Centurion Vinyl & Graphics Rusty9100 1987 - 1996 F150 & Larger F-Series Trucks 7 03-05-2014 10:04 PM
1975 Explorer Stripe Orange1975 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-28-2013 10:53 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
