ABS Grease fitting ?
I read a while back about installing a grease fitting in place of the abs sensor to grease the hub/wheel bearing.
I found these Riffraff Diesel: Front ABS Grease-able Block Off Fitting from clay while looking at the cost of an AE " they were on the same page ".
My question is this ......
By installing and using them which Bearing dose it apply grease to ? The needle bearing that the front axel shaft rides on. Or the actual sealed wheel/hub bearing.
Any one using these ? how are they ? do they really help the longevity of the front wheel bearings. Ive put 2 or 3 sets of hub assy on my truck in 6 years and if it will help not having to do that "As much" I'm sold.
When Andy (snowseeker) made his first run of these (though not anodized and shiny) I took a few pics of the grease fitting and how the grease moved through the bearing. It looks like the needle bearing doesn't get the added grease as the sealed hub bearing certainly does...
Ford Truck Enthusiasts Forums - View Single Post - Brotherhood of the travelling hub zerk
EDIT: After reading my old post, it seams back in 2011 I didn't know how to spell... "greese" vs "grease"
I believe Scott (Texas Outlaw) was the first to make a run of these, and he actually gave them away to anyone who wanted one at the time, just for the record. I haven't seen him post in quite a while though. He's a very good dude.
https://www.ford-trucks.com/forums/member.php?u=347252
You do.
Stewart
I have a 05' F250 4X4 FX4 and recently had a 05' F-150 4X4. Just got rid of the F150...after using the zerk on it...Well heres the story...I also have a 04' Tahoe...took the rotors and mounting brackets off today..and looked in the back...hmmmm ABS bolted in the same way..so I figured might as well check it out...took out the ABS, held in the same way as the fords with a small bolt...and guess what fits...the hub zerk.....just lettin ya know...This thing is versitle (sp)...
I believe Marv was the creator for the original zerk, turning one on his lathe. It was his design that Tex followed.
https://www.ford-trucks.com/forums/6...ml#post5019968
Stewart
Stewart
What i meant was, if you remove the ABS sensor i am assuming it will throw a code if you do not re-install the the sensor after greasing, right? Now with all that grease in there, i was wondering if it affects the sensors ability now. Maybe a dumb question, but i like to ask them instead of dumb mistakes.
Adding the grease through the ABS port does not affect the ABS sensor in any way.
Stewart
If you leave them out (as I have), the ABS system is disabled, which does not affect braking in any way. You will have the ABS light on until it burns out or is removed from the instrument panel.
You can use the fittings if you do not have the ABS. You just have to get the ABS hubs, remove the sensor and place the grease fittings in their place.
I can't believe the "question for Cookie" was asked six years ago!
Where does the time go?????
Pop
Ford Truck Enthusiasts Forums - View Profile: Texas Outlaw
I did make a run of these. Have been trying to make another run but just haven't had time. The company that I have worked most of my life for was recently sold and the new owners work me into the dirt, hence the no time for anything. Am about to make a change though....
