Gutless 2005 Ford F150 5.4
Hey guys
Last fall I bought a used 05 F150 crew cab with a 5.4. It is gutless. It is so bad that when i try and do a break stand to test for a brake torque test to try and get some codes i can put the accelerator all the way to the floor and it will NOT break the tires lose.
I have done:
a tune up with new plugs and fuel filter
Check the Catalytic converts
Replaced the fuel pressure control module
Cleaned the MAF sensor.
I am not getting any engine codes but plan to take it in again soon to have it rechecked. EDIT: forgot to add im getting 12 mpg :-(
Any suggestions? I heard from a friend something about the syncos on the cam shaft but didnt understand.
Thanks
PS i also posted this under the motor section but feel it would be better seen here.
I have done:
Thanks
How many miles? How bog/ what kind of tires? I've got an 04 lariat 4x4 running 33 mudterrains and it will roster em like its its job, but I also have a spectre intake a gryphon programmer and exhaust. I got lucky and it all costed me around 300 total. I also had another 2004 xlt with the 5.4 nothing done to it with 230k miles. Only time outa roasted them was when
my brother has a 2006 F150 ext cab short bed with the 5.4 and 3.73 gears thats bone stock and it will lay dual smokey burnouts like theres no tomorrow, my girlfriends brother has a 2004 F150 supercrew with the 5.4 but it only has the 3.55 gears and even with larger 33's his truck can lay a decent lines on the street. The day before i had my new tires installed i sent the old ones out in a blaze of smoke on my 5.4 powered F350 in my sig and for never doing it before on this truck i layed lines all down my street.
