Replacing oil cooler on 2008 F250 6.4 - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-08-2013, 05:48 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
EGR cooler failure seem to send the coolant to #8 and then you have some real problems...so yes proper coolant maintaince is a must.
Old 06-08-2013, 06:04 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
But unlike the 6.0L trucks where the EGR cooler is plumbed in series with the oil cooler, the 6.4L cooling system plumbs the two in parallel with each other. So a plugged up oil cooler shouldn't fry the EGR cooler, unlike a 6.0.
Old 06-08-2013, 06:20 AM
senix's Avatar
Quote:
that was a better answer!
Old 06-09-2013, 07:21 AM
SCR6.4 SCR6.4 is offline
SCR6.4 is starting off with a positive reputation.
UPDATE: I have an upcoming appointment with local Ford dealer to diagnose problem on P012F including how they plan to fix in great detail- -how to flush properly and install new oil cooler. Information on how to properly flush is readily available and I have seen many threads on how NOT to do it. Kinda scary that there are quite a few threads that bash the Ford dealers--so my alert level is high and trust level is low. Just setting up the appointment ended is a discussion bashing the 6.4 and recommending DPF and EGR delete.
Old 06-09-2013, 08:29 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
I thought my oil cooler was bad, but the coolant had an air lock somewhere or something, and when it finally got figured out, the oil cooler numbers are back to normal.
Old 06-09-2013, 09:03 AM
That would be a great outcome if I did not need a new oil cooler. Fingers are crossed. Installed Edge CTS this weekend and within 10 or 15 minutes, the ECT was hovering in the 194 range while the EOT steadily increased to 217 without any hard driving. Usually takes 20 minuets to throw the wrench and I have not been able to drive for 20 minutes to see the temp delta between ECT and EOT before the wrench comes on. Will do that today. I have been reading it is 15 degrees but I have been at 20 degrees with no wrench so far.
Old 06-10-2013, 06:24 AM
Spent some time driving for about one hour in the mountains of NC yesterday. Air temp was 70 to 75. EOT rose to about 20 degrees above ECT and stayed in that range except for when we hit some moderate hills. ECT rose to 198 and EOT rose to 228- -20 degrees. After about 20 minutes at this differential, the wrench light came on. Max temp diff was maybe 22 degrees. Taking to dealer ship tomorrow.
Old 06-10-2013, 07:13 AM
senix's Avatar
don't clear the code.
Old 06-10-2013, 07:21 AM
10-4. Will not clear the code. THX!
Old 06-14-2013, 06:40 AM
Dealer still has not isolated problem causing P012F code. Could a bad T stat (or both) be the culprit? Could someone help explain that?
Old 07-01-2013, 02:47 PM
jakedsnk jakedsnk is offline
jakedsnk is starting off with a positive reputation.
Hey, first post here. I have an 08 with a Mini Maxx tuner and am seeing 195-205 ECT and up to 240 EOT. I am not getting any codes or the wrench. Has anyone seen this happen before?
Thanks,
Jake
Old 07-01-2013, 03:59 PM
blue turd blue turd is offline
blue turd is starting off with a positive reputation.
Have you had latest flash 11B23. I had flash done on my truck and computer saw 30 degree differential and put truck in limp mode. Ended up needing tstat and oil cooler
  #28
Old 07-01-2013, 04:05 PM
I'm not sure, I've only had the truck since Feb. How do I check what the flash rev. is?
  #29
Old 07-01-2013, 04:06 PM
I also have not had the truck go into limp mode.
  #30
Old 07-01-2013, 04:26 PM
Final Thoughts: Replaced both T stats and flushed coolant system, the correct way with VC 8 and 9, etc. Error code cam back, so had to replace the oil cooler. Unlike previous owner, I will maintain coolant system the way it should have been all the time.
Thanks for everyone's comments. ECT and EOT are now running a max of 5 degree delta.
Oil Additives in 6.4 rob0688 6.4L Power Stroke Diesel 8 11-04-2016 10:14 PM
6.4 Oil cooler replacement Blurr4x270 6.4L Power Stroke Diesel 10 12-14-2015 10:52 PM
oil line to use for remote oil filtration system speakerfritz 6.4L Power Stroke Diesel 0 12-11-2015 08:42 AM
High EOT Thinking about an External oil cooler by IPR.. thoughts?? badass_f250 1999 to 2016 Super Duty 7 09-17-2015 11:16 PM
Typical problems for the 6.4? Cam_Man595 6.4L Power Stroke Diesel 17 11-22-2011 04:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
