Cab Lights - Page 4 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Cab Lights
  #46
Old 06-23-2013, 09:21 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
I think only the first is needed.
  #47
Old 06-23-2013, 09:49 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Yep, just the outer skin.
  #48
Old 06-24-2013, 04:32 AM
kupiec20's Avatar
kupiec20 kupiec20 is offline
kupiec20 is starting off with a positive reputation.
ok. now how do i get my OEM harness tucked up in there?
  #49
Old 06-24-2013, 07:15 AM
TyBragg's Avatar
TyBragg TyBragg is offline
TyBragg is starting off with a positive reputation.
Take the passenger side kick plate/trim (where your feet are when sitting in the passenger seat) off. Then take off your passenger side sun visor - you'll need access to the hole where it mounts to fish the harness (you don't have to do this, but I think that extra access hole makes it much easier). Then you can take something like a coat hanger or other stiff wire and fish that from the first cab light hole down the passenger side A pillar to where you took the kick plate off. You can use the hole from where the sun visor mounts to guide your wire in to the A pillar. Once you have that fished, then you can attach the harness to your fish wire and pull it down. Once you have the bottom part of the harness fished, then you've got to start fishing the upper side of the harness from one cab light hole to the other. We used one of those nifty little "parts grabber" things (i have no idea what it's called) - you know, where you push the button on one end and the tiny claws open up on the other end. Don't know if that makes sense...Anyway, we started at the very next cab light hole from where you fished the wire down, then pulled the harness to that hole. Then moved to the next, etc. until it was all the way across. It's really not too bad! It helps to have two people.
  #50
Old 06-26-2013, 10:10 PM
kupiec20's Avatar
thanks for the help.
nice write up tybragg.
ok i have the harness thru the visor hole and all the wires to each hole with cab lights installed. so all i need to do is pull the wire down the pillar.
the problem im having is getting the snake up the pillar. whats in that pillar that can be damaged? any tips. ty
  #51
Old 06-26-2013, 11:13 PM
ReBilld's Avatar
What ever you're using for a snake, run it down the pillar from the visor hole. Once it comes out down at the bottom, tape the harness to it and pull it on down through the pillar. That's how we did both of Tyler's.
  #52
Old 06-27-2013, 12:19 AM
fordman67's Avatar
Yea!what he said...its a bit agervating though.
  #53
Old 06-27-2013, 07:30 AM
kupiec20's Avatar
so when i go to snake the metal wire down the pillar and it gets stuck and i start jamming it down out of frustration an i going to damage anything
  #54
Old 06-27-2013, 07:37 AM
fordman67's Avatar
No.i dont think there is anything. else in there.at least i didnt have.it will go though.
  #55
Old 06-27-2013, 05:23 PM
ReBilld's Avatar
Quote:
X2 ^^^^^^^^
08-10 XL Oem Fog Light Install Issue F.X.5 1999 to 2016 Super Duty 3 11-30-2015 05:06 PM
How to wire in stock factory options. 81-F-150-Explorer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 74 08-10-2015 03:23 PM
Trailer wiring bigcountry1009 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 08-10-2015 02:06 PM
Backup Camera Harness mav 6.7L Power Stroke Diesel 2 05-16-2013 09:08 AM
leads on high amp alternators and wiring harness? proeliator Electrical Systems/Wiring 8 01-04-2003 01:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
