Cab Lights
  #31
Old 05-28-2013, 06:18 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Bad news fellas, while the headliner is easy to reupholster, doing one in a crew cab truck involves removing either the rear window or the windshield. Removing the rear window really isn't all that bad a job. Heck this monkey has done a couple of them and I haven't broken one yet (knock on wood). You do have to remove it though, because it won't go out through the door.
  #32
Old 05-28-2013, 06:57 AM
fordman67's Avatar
fordman67
fordman67 is offline
That's what i was afraid of...but i did find the connector for cab lights.that was easy.
  #33
Old 05-28-2013, 09:34 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Thanks for the good news Nate! LOL
  #34
Old 05-28-2013, 09:45 AM
DIYMechanic
Yeah sorry to be the bearer of bad news, Glenn. Unfortunately though, in this case that seems to be the reality of the situation.
  #35
Old 05-28-2013, 10:14 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Question
Yes, I have read that Nate is right. What is wrong with your headliner?
  #36
Old 05-28-2013, 02:34 PM
oldbird1965
Its not to bad but there are a few cigarettes burns on it and the wife was thinking that it has trapped some smell in it. If you try to wash it, it will fall down probably.
  #37
Old 05-28-2013, 03:22 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Sure it will.........if you fold it just right!
  #38
Old 05-28-2013, 03:29 PM
DIYMechanic
  #39
Old 05-28-2013, 06:15 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Heard that Tyler got the lights today. Hope they arrived safely(he will check later after some other stuff)!
Since im on photobucket already I figured id share some pics.
Heres the lights/harness.
Here is the location beneath the passengers kick panel. You can see the far right i pulled off the connector the lights.
It was weird though... I got 4 good cab lights off of one truck and went to get the harness out and it was on the drivers side kick panel...
That was on a box/ambulance OBS though.... Cant remember exactly, but it wasnt the standard truck.
So I went to get the other lights from another and snagged that harness in its usual location.
  #40
Old 05-29-2013, 05:01 AM
DIYMechanic
Looks good Alex. You even got him a spare!
  #41
Old 05-29-2013, 06:19 AM
TyBragg's Avatar
TyBragg
TyBragg is offline
Yes he did, and I appreciate it! Can't wait to get em on! Thanks again Alex!
  #42
Old 05-29-2013, 09:49 PM
fordman67's Avatar
fordman67
Yea..thanks tyler...i was blocking the presence of mine out..now i have all the front trim out and rewiring mine correctly sine what ever moron botched the job and dang near burnt this puppy down...
it is good! :-)
  #43
Old 05-29-2013, 11:53 PM
oldbird1965
If the truck didn't come with them, then I would guess that's some serious hole cutting!!
  #44
Old 05-30-2013, 12:06 AM
fordman67's Avatar
fordman67
I had them added at some point before my buddy bought it.the power was run to the fuse block with a nasty mud covered external fuse holder with wire stuck in dimmer circuit.so the clearence lights dimmed with dash lights lol.and at some point the wire burned up and was melted into a pillar trim...it had been repkaced but the damage is very visible.I'm very happy to have it run inside the pillar correctly and to correct location!
  #45
Old 06-23-2013, 08:14 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
so i started drilling today with a little help...
what i didnt realize that i encountered two layers of sheet metal.
do i drill through both or just the exterior layer?
Quick Reply: Cab Lights
