Cab Lights - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Cab Lights
Old 05-24-2013, 09:43 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
Originally Posted by TyBragg View Post
Yeah, with your little double set of cab lights....lol
35mph head winds today, I hope they don't blow off, LOL
Old 05-24-2013, 09:54 AM
TyBragg's Avatar
TyBragg TyBragg is offline
TyBragg is starting off with a positive reputation.
Quote:
haha......
Old 05-24-2013, 10:39 AM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
Thanks all. Glad I could help out! This local yard is family owned and they 'specialize' in powerstroke diesels.
They get a lot of them. There was about 8 total the other day. lol
I kinda feel bad if you can get them all new for $40... but as you said you do have a factory harness!
Old 05-24-2013, 04:15 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
I tried to rep Alex, but no can do
Old 05-24-2013, 04:56 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Since I am apparently unable to be lucky enough to buy a truck with cab lights, I've been looking for some. We had a set that I put on my old EC, but then I sold it when I found my CC, which does not have them. They say hindsight is 20/20, and I would have never put them on that truck if I knew I was going to find my CC. Does anybody have a set with the factory wiring harness lying around in a corner somewhere they may want to part with? Even just the wiring harness would be good. I've looked at the ones from LMC trucks, and I may eventually get them for the new lenses, but I'd like to have the factory wiring harness so I don't have to splice into the wiring. Just thought I'd ask.
I may have a set here. They are factory and are a bit hazy/faded. They are complete with wiring harness if I have them. If I have them they are yours.
Old 05-24-2013, 10:21 PM
Quote:
I tried too Bill. No Alex or Glove!!
Old 05-25-2013, 06:04 AM
kupiec20's Avatar
kupiec20 kupiec20 is offline
kupiec20 is starting off with a positive reputation.
now where does the harness plug into?
$15 at a bone yard down the road.
Old 05-25-2013, 09:41 AM
tshrager's Avatar
tshrager tshrager is online now
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I got glove, but not Alex
Old 05-25-2013, 10:49 PM
ReBilld's Avatar
Plugs in behind the passenger side kick panel, then runs up through the pillar to the top of the cab.
Old 05-26-2013, 09:43 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Is it a single wwire plug? Mine are hooked to the dimmer by po i guess...thinking i should go ahead and fix it...maybe recover the headliner too...
Old 05-26-2013, 09:53 AM
tshrager's Avatar
Quote:
Speaking of headliners, mine was pristine, till I helped a buddy move and I was putting a bunch of his wife's clothes on the back seat. I stabbed that sucker like 5 times with hangers. Just kept doing it like a moron. I was so mad at myself for that. At least I did it though.
Old 05-26-2013, 10:03 AM
Are these head liners hard to remove and replace?
  #28
Old 05-26-2013, 10:17 AM
kupiec20's Avatar
real easy. well it was for a regular cab...im sure a CC wont be as easy. just pull the liner and board out together.
lay it down and pull old liner off ans go to any fabric store and pick the fabric you like and you can find a can of 3M spray sold at most fabric stores.
just spray the 3M glue on the board and lay the fabric out and your done. my choice was camo. ill try to get a pic.
if i can do it anyone can. fyi glue sets up pretty quick. good luck
  #29
Old 05-26-2013, 10:41 AM
Are there clips or anything holding the board up?
  #30
Old 05-26-2013, 11:00 AM
fordman67's Avatar
The plastic trim all around and across windshield hold it up mostly.also dome lights.its easy.I'm not sure about the logistics of getting the cc out of the cab.todd.u need the "yes its my truck...no i won't help u move " bumper sticker lol
08-10 XL Oem Fog Light Install Issue F.X.5 1999 to 2016 Super Duty 3 11-30-2015 05:06 PM
How to wire in stock factory options. 81-F-150-Explorer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 74 08-10-2015 03:23 PM
Trailer wiring bigcountry1009 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 08-10-2015 02:06 PM
Backup Camera Harness mav 6.7L Power Stroke Diesel 2 05-16-2013 09:08 AM
leads on high amp alternators and wiring harness? proeliator Electrical Systems/Wiring 8 01-04-2003 01:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
