core support mounting kit help needed - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 05-23-2013, 08:45 AM
TCAPer's Avatar
TCAPer TCAPer is offline
TCAPer is starting off with a positive reputation.
I am in the process of replacing my core support on my '63 F100 unibody and I can't find the correct kit for bolting the support to the frame. I noticed in the shop manual that the unibody mounting kits have a spring which has to be tightened down to a certain height, but all of the kits I have seen don't have this spring in them. I did find variations of the part number: C1TZ-8125-S or else the suffix KT, but the pictures didn't show what I need.
I suppose I should just order some hardcopy catalogs from the different suppliers, because I spent over three hours last night trying to find the correct kit online or on their downloaded catalog. I have the hipo parts cd too and couldn't find it in there either. Guess I'm just too "old school" - I need the catalog in my hand....
So if anyone has the correct kit number or can steer me in the right direction, I would greatly appreciate it. Thank you very much....
Old 05-23-2013, 09:50 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
No one makes a kit with the springs.
If you want the springs you need the old ones or source some from mcmaster carr.
Use a longer bolt on the 61 to 64 kits currently produced.
Garbz
Old 05-23-2013, 10:10 PM
TCAPer's Avatar
Thank you so much for your help and information. I only wish I had posted here first last night rather than spend 3 hours looking for nothing....
BTW - do you know the reasoning why only the unibody has the spring?
Thanks again.
Old 05-29-2013, 12:43 AM
NONclow NONclow is offline
NONclow is starting off with a positive reputation.
I believe it has to do with frame flex. With the cab/bed moving together, the core support has to be isolated to the body, not the frame, to avoid cracking between cab/bed.
Questions about 61-63 trucks IvelDesigns 1961 - 1963 F100 Unibody 48 05-30-2015 03:14 AM
radiator support bushings?? sean9049 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-21-2015 01:02 PM
Oil pump O-ring unibody62 1961 - 1966 F-100 & Larger F-Series Trucks 8 10-25-2013 12:15 PM
Parts to mount front clip KsCop 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-20-2013 10:12 PM
Radiator Support for a 1966 . . . & question abt. quality of patch panels . . . JoeVR5 1961 - 1966 F-100 & Larger F-Series Trucks 21 07-24-2013 10:43 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
