Ignition coil heating up on 89 F-700 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-22-2013, 11:44 PM
Delta Dirt Delta Dirt is offline
Delta Dirt is starting off with a positive reputation.
Got a 89 F-700 with a 429 factory propane engine------this appears to me to be the Duraspark II ignition system.
Bought this truck several years ago-------but, have randomly had ignition problems over a period of several years---but recently have been going through problems with the coil heating up. Just replaced both coil and brain box module-------coil heated up and engine quit in approximately 10 minutes run time. Let cool down-------cranked back off again.
I have an aftermarket tach wired to the coil on the negative side (same as factory wiring harness).
Anybody ever have problems with these aftermarket tachs heating the ignition coils up?? (am going to try without the tach hooked up tomorrow)
What other suggestions to look for here--------all voltages check on the money across the system.
All suggestions apprecitated--------thanks
Delta Dirt
Avon, Ms 38723
Old 05-23-2013, 02:30 PM
Have re-checked voltage readings this morning-------7.53 on the run and 12+ on start.
Had wondered if we had missed the ballast resistor step down somewhere along the line--------but apparently not.
Still puzzled.
Hope to work on it some more this afternoon.
Delta Dirt
Old 05-23-2013, 11:30 PM
No progress this afternoon.
I moved the follow up on this question over to the 80-------86 model F-150 forum. The F-700 appears to be running the same Duraspark II system that my old 84 Bronco had. Lots of Duraspark discussions over there.
Still looking for answers.
Delta Dirt
Avon, Ms 38723
Ignition Control Module Glenn.b1 1987 - 1996 F150 & Larger F-Series Trucks 13 05-09-2015 03:05 PM
Duraspark II/HEI conversion failed sixofspades Ford Inline Six, 200, 250, 4.9L / 300 1 02-14-2014 09:23 PM
coil to use when running the resistor by pass on Dura Spark II Delta Dirt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-26-2013 09:56 PM
Factory tach rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-03-2013 11:45 AM
any difference between Duraspark II systems on F-150s and F700 Delta Dirt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 05-28-2013 11:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
