HELP I have a leak - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
HELP I have a leak
Old 05-22-2013, 10:59 PM
thinksnow thinksnow is offline
thinksnow is starting off with a positive reputation.
HELP I have a leak
When I was flushing my radiator and changing my coolant I noticed there was some oil on the passenger side of the radiator. What ever that wetness was has progressed to leaving small puddles of some oil based liquid below the passenger side head light, about the size of a silver dollar after the truck sits over night. Looking through the grill you can see the whole passenger side upper corner of that front cooler is saturated in oil. I went on rockauto.com to check out what cooler this is. The unit seems to handle a combination of things; its a condensor, oil cooler (motor oil or trans fluid, it doesnt say?), and dryer assembly, the motor craft part does mention its also a power steering cooler. So......what is this oil drip??? I'm wondering if the cooler is shot or do I just have a leaky fitting. Regardless of what it is, it is going to be a PIA to get to the side of that upper corner. It's looking like I have to pull the head lights and grill out to get to it.
ANY IDEAS? Throw it on out there.
Old 05-23-2013, 10:53 PM
Well I have it figured out. The top of the condensor doubles as a power steering fluid cooler. I checked the power steering fluid reservior and it was super low. However the lines go in and out of the condensor from the drivers side. My leak is on the top passenger side corner so Im guessing the condensor has been comprimised. A friend who works at a dealer told me I should bring it to the shop because of the special equipment I would need for the A/C system. At this point I have a vacation planned and not a whole lot of spare cash; so I'm going to give it a shot of the Bars Leaks power steering treatment. Hopefully that will slow it down for a while.
does my 351w have an oil cooler? choate 1987 - 1996 F150 & Larger F-Series Trucks 8 09-09-2015 09:24 AM
Oil Leak @ Oil Cooler Adaptor Fixed! HearseDriver Modular V10 (6.8l) 2 05-28-2015 12:42 AM
HELP NEEDED OIL COOLER PROBLEM BIG-DADDY-F350 1999 - 2003 7.3L Power Stroke Diesel 5 01-11-2015 10:49 AM
Other causes of EGR cooler failure? billbot 6.0L Power Stroke Diesel 13 01-13-2014 10:29 AM
6.0 transmission cooler install on OBS 96 f250 wildstang 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-16-2013 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
