Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
escape 02 v6 error p113
Old 05-22-2013, 10:04 AM
Brady Miclos's Avatar
Brady Miclos
Brady Miclos is offline
Hi i have error p113 on my escape the iat reading 29c what can i do where is the iat sensor
Anyone
Thanks
Old 05-22-2013, 11:37 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Go back and get the rest of the 4-digit DTC. That one is incomplete.
Old 05-22-2013, 12:08 PM
Brady Miclos
Po113 or p0113
Old 05-22-2013, 01:49 PM
projectSHO89
What was the ambient temperature when the 29C reading was taken?
Old 05-22-2013, 06:26 PM
wptski's Avatar
wptski
wptski is offline
Anyone
Thanks
A code P0113 may mean that one or more of the following has happened:
•Internally failed IAT sensor
• Faulty connection at IAT sensor
• Open in IAT ground circuit or signal circuit
• Short to voltage in IAT signal circuit or reference circuit
•IAT harness and/or wiring routed too close to high-voltage wiring (e.g. alternator, spark plug cables, etc.)
• Faulty PCM (less likely but not impossible)
I believe that the IAT that once was by itself is now included inside the MAF sensor.
Old 05-22-2013, 08:31 PM
Brady Miclos
Ambient temp 25 to 27c around
Yes maf reads the intake temp too
Old 05-22-2013, 09:44 PM
FireMe's Avatar
FireMe
FireMe is offline
Is the code from the key-on-engine-off test, the key-on-engine-running test, or just in memory?
Have you turned the key on or started the engine with the MAF connector disconnected? That will set that code.
Are the MAF sensor connector terminals clean, dry, and free from corrosion?
Old 05-23-2013, 11:29 AM
Brady Miclos
The temp with engine running i dont try disconected maf
What about clean maf clear the error n try scan again the problem of my scape stall out
bigcountry25
2004 - 2008 F150
05-07-2014 09:06 PM
Bibbop
04-07-2014 06:03 AM
cabledog77
1997 - 2003 F150
07-26-2009 06:30 PM
gregj
1997 - 2003 F150
11-01-2004 05:06 PM
bobrickner
12-09-2003 09:47 AM
Quick Reply: escape 02 v6 error p113
