EDGE INSIGHT - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
EDGE INSIGHT
Old 05-22-2013, 09:20 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA VONxRUBENxLA is offline
VONxRUBENxLA is gaining momentum as a positive member of FTE.
EDGE INSIGHT
I HAVE A INSIGHT CS AND ALL OF A SUDDEN IT JUST STOPPED WORKING I HAVE UNPLUGGED IT NUMEROUS TIMES LEFT IT UNPLUGGED AND IT STILL WONT POWER ON. I BOUGHT THIS LESS THAN A YEAR AGO.
HAS ANYONE ELSE EVER HAD THIS PROBLEM?
Old 05-22-2013, 01:12 PM
edjunior's Avatar
edjunior edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
NO, BUT WHY ARE YOU YELLING AT US??
Old 05-22-2013, 01:27 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
YES I HAD THIS PROBLEM ONCE, I UNPLUGGED IT, STOPPED YELLING AT IT, PLUGGED IT BACK IN & AND IT WORKED...LOL
Seriously, mine quit after 1 1/2 years so I was SOL on the warranty. I replaced it with a Scanguage II. Did you verify that your DLC isn't the problem?
Old 05-22-2013, 06:44 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Check your cigarette lighter fuse. It also powers the data connection.
Old 05-22-2013, 07:26 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
All caps when typing is considered yelling. Redford has the right idea about the fuse for the cig lighter.
Only other option is warranty with Edge.
Old 05-23-2013, 10:03 AM
sorry everyone for yelling i had just got into work and had to do some stuff that caps were on.
yes i also emailed edge about this and they said the samething as Redford cig lighter. i can also just push the cig lighter in and if they works then the fuse is good im assuming? but i have been wrong a few times in my life. thanks for the help fellas
Old 05-23-2013, 10:20 AM
senix's Avatar
Correct if the cig lighter works then there should be power to the OBD port.
Can't Submit Vehicle Health Report Leonandlisa 6.7L Power Stroke Diesel 22 12-24-2014 12:01 PM
Edge insight issues screwy 6.7L Power Stroke Diesel 9 11-30-2012 08:19 PM
Edge Insight CTS and Battery Charger interaction Piolet 6.0L Power Stroke Diesel 64 03-17-2012 12:50 AM
Edge Insight CTS - Set-up Help 401-k 6.0L Power Stroke Diesel 7 01-29-2011 04:18 PM
Edge Insight question RuralSurvivalGuide 6.4L Power Stroke Diesel 12 02-05-2010 11:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
