Water,oil, and volt mechanical gauges
Old 05-22-2013, 12:00 AM
bigcountry62's Avatar
bigcountry62
bigcountry62 is offline
Okay so I bout a the sunpro 3 gauge cluster from a buddy and if course he don't have anything other than the gauges them selfs, so what do I need for the oil gauge?? And how do I hook up the water temp gauge? I have a 400 with edlebrack performer intake
Old 05-22-2013, 12:15 AM
co425's Avatar
co425
co425 is offline
Sunpro's are so cheap it's probably cheaper to buy a whole different set of gauges. The sending units for the oil pressure and water temp probably cost more than a whole new set. The volt gauge should have the wiring terminals already in the gauge.
Old 05-22-2013, 12:17 AM
hoffy's Avatar
hoffy
hoffy is offline
you can pick up oil pressure by teeing off the oil pressure sending unit on the block right behind the intake manifold. usually the gauge comes with plastic tubing with a compression fitting that threads into your tee fitting. water temp gauge should have the sending unit hooked to the gauge it can plumb into the water outlet on your intake manifold where your radiator hose is hooked to.
Old 05-22-2013, 06:54 AM
Wbruiser2's Avatar
Wbruiser2
Wbruiser2 is offline
To save you time and aggravation, follow this advice.
Old 05-22-2013, 09:27 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Agreed, the whole set is $30 new; don't bother with an incomplete set.
There are no sending units with mechanical gauges; that's the whole point. The oil pressure gauge uses a compression fitting and a nylon or copper tube. The temperature gauge uses a bulb that runs up to the gauge through a tube protected by a flexible coil. Usually the gauges come with a handful of adapters, reducers and fittings to make them universal.
Senor del Taco
11-17-2011 08:11 PM
CharlesNeff
07-17-2007 06:51 AM
ejpreston
2004 - 2008 F150
08-01-2005 10:19 AM
scrammer
Aftermarket Products
09-22-2003 09:59 AM
Quick Reply: Water,oil, and volt mechanical gauges
