Exhaust Flange 91 F-250 5.8
I built a new engine for my f-250 4x4. The truck had headers on it that were junk so I decided to replace the headers with stock manifolds. Motor is a stock build. The problem that I am running into is the collector on the end of the pipes that hook to the manifold. I got a pair of pipes from another similar F-250 5.8 truck. Not sure exact year but same body style as my 91. The donor truck was also a 2wd. The problem that I have ran into is the flanges on the end of the pipes. The bolt holes are too narrow. They are approx a bolt width too narrow on each side. http://www.summitracing.com/parts/wlk-40585/overview/ This is a set of pipes that I found. Will these hook to my new exhaust manifolds. The manifolds were ordered for the 91 truck. I have double checked the part numbers and the information on the box. Is there a difference in the bolt spread on some of the 5.8s between the year models. I would hate to spend the money to buy the new pipes and them still not fit.
Exhaust flanges
OK, got in a new H pipe made by Walker. It is a exact replacement for the 91 F-250 E4OD 4x4 with the 5.8. It has the same flanges on it as the ones I got from the junk yard. Has anyon else ran into after market manifolds with the wrong spacing on the flange bolts. The flange holes are approx 3.875" apart (3 7/8").
The Bassani y-pipe I used on my old 1992 F350 w/5.8L engine fit like a glove. Perhaps the supplier shipped you manifolds for a 5.0L engine? The first Bassani pipe they shipped me was for a 5.0L equipped truck. The part number on the box was correct but it was very obvious the pipe inside was wrong.
Exhaust flanges
Thanks for the responce. I am seriously wondering if the bolt on the collector end of the manifold are not off a little. The truck had a junky old set of headers that were rusty and wouldnt seal off so I decided to junk them and got back to stock manifolds. I went to the junk yard and got an H pipe off of another F-250 with a 5.8 in the same body style (87-92). The flanges on the collector end had narrower bolt holes as does the new manifolds. According to the numbers on the box they are for the 88-92 F250 5.8.
