Boss Sport duty plow on an ex
Old 05-21-2013, 05:18 PM
reospw's Avatar
reospw
reospw is offline
Has anyone put a plow on their excursion? I acquired a 7'6" plow that came off a dodge hemi pick up. Is their a plow mount that will work with the Ex?
Old 05-21-2013, 06:17 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
You will probably hate the front end after putting the plow on due to the under-rated springs. If you can find the manufacturer you would probably need to contact them for a bracket/ wiring.
Old 05-22-2013, 10:06 PM
tims01's Avatar
tims01
tims01 is offline
many have put plow on ex
Old 05-22-2013, 10:34 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i work at a Boss dealer and i own a 7'6" boss super duty plow.
it will be a a slightly narrow plow for the truck and i dont know if boss makes a sport duty under carriage for the super duty ford trucks. far as i know(have seen) is the normal kits and the 10' kits for f-450/550s. that will be your issue.
i currently have a superduty/excursion under carriage waiting to go on my Ex once i get the wiring. that way i'll have my excursion as a backup if something happens to my plow truck.
as stated if your on stock springs, you will be sitting on the bump stops.
a 2013 f-350 i just installed a 9'2" vee blade and wings on.
Old 05-24-2013, 06:31 PM
mtnsammy's Avatar
mtnsammy
mtnsammy is online now
I installed a front hitch and use a hitch mounted Snow Sport. Works fine but getting in and out a lot is no good. It is a home plow not commercial. I hear Meyers has a nice Home Plow too that uses a front hitch. I will be trying it this winter. I plow about 100 feet of city road, I can't wait for the city to come by, and my shop plot. So far I like the simple plow but I am getting lazy and want cab controls.
Old 05-27-2013, 05:33 PM
wannaBelkhuntin's Avatar
wannaBelkhuntin
wannaBelkhuntin is offline
Don't know anything about the Boss plow but I installed a Western Ultramount on my Ex. despite all the naysayers on here. I did add Timbren air bags that I bought cheap from Howler4X4 here on FTE. Most times I didn't even use 4 wheel drive.
The frame mount was easy to install and only added 100 lbs or so and most of that comes off for the summer [ the receivers]. My ultramount plow only takes a minute to install when needed and even less to remove so I never had to drive down the road with it on.
Old 06-07-2013, 07:53 PM
7475ih's Avatar
7475ih
7475ih is offline
Are the Ex plow mounts the same as an f250?
Old 06-07-2013, 08:55 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yes, 99-07 SD mounts also fit 00-05 excursions.
this goes for BOSS mounts, others may vary.
Old 06-07-2013, 10:52 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by wannaBelkhuntin
...but I installed a Western Ultramount on my Ex. despite all the naysayers on here.
What naysayers? Where?
Stewart
Old 06-08-2013, 08:39 PM
fsmt's Avatar
fsmt
fsmt is offline
8' fisher minute mount.... All the same mounts as my old SD.
PTL.PARKS
1999 to 2016 Super Duty
12-16-2011 02:34 PM
pkenn7
02-24-2011 06:56 AM
PinkyRingz
2004 - 2008 F150
13
02-05-2008 05:45 PM
craneman74
2004 - 2008 F150
12-24-2006 07:53 AM
mxz7
01-08-2003 12:46 PM
Quick Reply: Boss Sport duty plow on an ex
