2006 F250 Add-A-Leaf Suggestions
i paid $90 for my long add a leaf from a spring shop, they bent the spring cut it to the length i wanted and drilled the center pin hole and the slip pad holes at the end because i wanted them. BUT the spring is not coated or anything and i had to put it in myself. At least ANY spring you buy will be coated in a heavy duty rust Resistance paint and match the factory springs. I prepped my add a leaf primed it and painted them and within a few m months they start to flake and rust and i have to wire wheel them and re-paint again. Yet the stock springs still are rust free.......
-you will need two big six inch c-clamps and clamp them around your spring pack
-remove old u-bolts and lower axle away from spring
-slowly loosen the c-clamps after you remove the old center bolt
-after clamps are off install the add-a-leaf
-re-install the add-a-leaf into the pack, install center bolt
-get yourself a straight edge and make sure the springs are square with each other take a step back and look at the center bolt it should be straight up and down not on an angle front or back
-now completely tighten the c-clamp and tighten the center bolt with a hand ratchet ONLY
-lift up axle and install new u-bolts and torque to manufacture specs
