62 Unibody Tire Size - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 05-21-2013, 01:38 PM
62ESQ 62ESQ is offline
62ESQ is starting off with a positive reputation.
Does anyone know what is the closest radial tire size would be to 7.00 x 15 bias ply? I found that I have what looks to be the original bias ply spare tire under my 62 bed. It's a bias ply 7.00x15. I googled conversion charts and it seems that 215/75R15 would be close. I'd eventually like to get new tires that look close to original stock. Did the 62 unibody custom cab come with white walls? Were the bottle cap FORD hubcaps standard?
Old 05-22-2013, 10:25 AM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
215/75R-15 is what I had heard.
Old 04-14-2015, 03:33 PM
hoss73ford hoss73ford is offline
hoss73ford is starting off with a positive reputation.
235 75R 15s is what I would put on F100s unless you like undersize tires (which some do) The old 700 x 15s were 30-31 inches tall and the 235 75Rs are about 29.
Old 04-23-2015, 10:35 PM
Koolkat Koolkat is offline
Koolkat is starting off with a positive reputation.
Tire size
Yes, believe the standard and only cap were the bottle type caps. If you don't have a set, I could help you with that. I also have a spare wheel that is available. I took the centers from my stock wheels and fit them to new 15X8 hoops from Speedway, I am now using P265/75/R15 tires. I spaced the wheels so they were centered in the wheel wells front and rear. Good luck with your truck and have fun. I have been told that "fun" is what it is all about.
spare tires fitting under bed and differential speeds... mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-15-2017 02:59 PM
Double check my wheel/tire choice for 55 smon 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-16-2015 03:24 PM
1969 Bump Tire Source? NebraskaCowman 1967 - 1972 F-100 & Larger F-Series Trucks 2 08-30-2014 12:36 PM
I'm Looking for a 7.50 X 20 Tire! F500Mike 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 03-04-2012 06:59 PM
what is your opinion on bias ply tires? 76hi-boy Brakes, Steering, Suspension, Tires, & Wheels 1 01-29-2005 05:00 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
