Coolant flush - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Coolant flush
Old 05-20-2013, 09:34 PM
thinksnow thinksnow is offline
thinksnow is starting off with a positive reputation.
Coolant flush
Flushed out the Expy tonight, it left me a little confused. I drained and collected the old coolant. Topped off the system with water and ran the truck for a while with the heat on hi, then drained the system again. I repeated the process a third time. When I added the new coolant I could only get it to take 7 qts. It should take far more then that. That is going to leave my coolant strength far to low. Should I go for a long drive, come back and drain off more mixed coolant and replace it with pure coolant to increase the ratio. ???
Old 05-21-2013, 04:28 PM
Beechkid Beechkid is online now
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Well, I am betting that after your drive you didn't leave the heater on and when you drained it, the system left a qt or so within the heater system....really not that big of an issue....
What I would suggest is picking up a coolant bulb type tester (about $12) and test the freeze/overheat level....I think you will be surprised at where you are at....then if need be, drain a little and add 100% coolant- that should bring you up to where you need to be.
Help with coolant flush and fill 2001 Navigator 68bluebeast Expedition & Navigator 1 03-08-2015 09:48 PM
Coolant flush? Pat Taugher 6.0L Power Stroke Diesel 3 03-07-2015 09:39 AM
coolant flush - can anybody give me some advice? choate 1987 - 1996 F150 & Larger F-Series Trucks 2 10-01-2014 12:15 AM
Change out Anti-freeze question. captandy 6.0L Power Stroke Diesel 3 02-05-2014 12:49 AM
Coolant system flushed thinksnow 2004 - 2008 F150 3 05-23-2013 11:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
