Vin Decode - Ford Truck Enthusiasts Forums
Vin Decode
Old 05-20-2013, 08:22 PM
nerksa's Avatar
nerksa nerksa is offline
nerksa is starting off with a positive reputation.
Vin Decode
Appreciate a decode of my 1966 F250 4x4.
VIN
F26YR817734.
Old 05-20-2013, 10:29 PM
SuperSabre's Avatar
SuperSabre SuperSabre is offline
SuperSabre is gaining momentum as a positive member of FTE.SuperSabre is gaining momentum as a positive member of FTE.
F26 = F250 4 wheel drive truck. Y = 352 Cubic inch V8 2bbl engine. R = built in San Jose, CA. 817734 = built in February, 1966. If you post the information on your driver door warranty plate, we can give you additional information.
Old 05-21-2013, 07:39 AM
nerksa's Avatar
Warranty data plate
120 M F260 B81 A B5
06800 172 4000 711779
Thanks.
Old 05-21-2013, 10:40 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Hi welcome to FTE. I looked at the pics of your truck in your profile. Looks to be a solid survivor just a little rough around the edges. Great to see another factory 4wd hitting the roads or at the very least being restored.
Old 05-21-2013, 11:40 AM
nerksa's Avatar
Thanks
I reviewed your projects. Wish I had your talent and experience. We shall plow through and learn along.
Old 05-21-2013, 04:42 PM
SuperSabre's Avatar
Here's the rest of your warranty plate decode: 120 = your wheelbase in inches. M = Wimbledon White exterior color. F260 = 6800 pound GVW rating 3/4 ton 4x4 truck. B81 = Blue Crush Vinyl and Blue cody pattern woven plastic upholstery in a Custom Cab. A = NP435 4 speed manual transmission. B5 = Dana 60 limited slip rear axle with 4.56 rear gears. 6800 = max gross vehicle weight rating. 172 @ 4000 = your NET horsepower and the rpms where achieved. 711779 = a Domestic Special Order vehicle, ordered from the Los Angeles District Sales Office. Unfortunately, the records that could say exactly what your special order entails are no longer available. Frequently, it has to do with special paint, but apparently not in your case as the Wimbledon White code is given and, from your album pictures, it certainly is painted Wimbledon White. Hope this helps.
Old 05-21-2013, 06:26 PM
nerksa's Avatar
Beautiful. Thanks.
Old 05-21-2013, 09:39 PM
Buzz44's Avatar
Quote:
Thanks if you need any help or info just let me know.
66 ranchero Vin decode tmcquaw Ranchero & 1961 - 1967 Econoline 28 09-06-2014 08:03 PM
vin pineflatg1 1961 - 1963 F100 Unibody 2 05-12-2014 10:02 PM
VIN # Bobark 1967 - 1972 F-100 & Larger F-Series Trucks 6 03-09-2014 06:11 PM
vin decoder 76ClydeF100 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-21-2014 08:50 AM
VIN decode yewdall 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-23-2013 02:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
