Holley Terminator EFI - Ford Truck Enthusiasts Forums
Old 05-20-2013, 06:26 PM
abrojal's Avatar
abrojal abrojal is offline
abrojal is starting off with a positive reputation.
Hi.
This is my 400 with Tmeyer pistons
Now Im running a Barry Grant Road Series 625CFM but Im planing to get a bolt on EFI system.
My carb has a nice throttle response an I think this EFI system could be better. Also EFI has another advantages.
Does anyone have any experience with a Terminator EFI?
Tnx
Old 05-22-2013, 11:18 AM
abrojal's Avatar
anyone has experience with a terminator EFI? not even an avenger?
Old 05-22-2013, 04:03 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I have not. I hear then the Edelbrock E-Street set up works pretty good.
Edelbrock.com - Electronic Fuel Injection - Introduction
Old 07-17-2013, 08:42 AM
dimora's Avatar
dimora dimora is offline
dimora is starting off with a positive reputation.
I am very interested in your review if you do indeed install the Terminator EFI.
I am using a smart-phone app on my iPhone called RoadTrip to track my fuel economy (or lack thereof). My build is in my signature.
Please keep track of your economy (if you do run a carb first) so we can all see how much fuel EFI saves.
Obviously the easy start, better throttle response, and always correct A/F ratios are benefits as well, but my interest in the fuel economy is to determine the break-even point with an upgrade. High teens would certainly make it justifiable from where I am at now...
Here is my fuel economy with my Edelbrock Thunder AVS 650 CFM carb - this is around-town driving with maybe 30% freeway miles:
Old 07-17-2013, 08:53 AM
dimora's Avatar
Here's a good read on a different EFI system upgrade (Holley Avenger) whish is about half the price of the Terminator - they only picked up 1 MPG average on this one:
Holley
Old 07-17-2013, 07:18 PM
BuzzLOL BuzzLOL is offline
BuzzLOL is starting off with a positive reputation.
.. Good looking 400 in that picture... what's the heads and cam?
Old 07-22-2013, 05:48 PM
0ldman 0ldman is offline
0ldman is starting off with a positive reputation.
I wonder how that would work on something built a little more reasonable. A cam with 230/240 @ .050 isn't subtle.
The air velocity is going to suck at low RPM. Still a valid article, most of us don't have entirely reasonable engines, but a truck motor or a slightly hotter than stock engine would show more of a difference.
Old 07-23-2013, 06:03 PM
.. I was surprised in that EFI test link that a 383" with 231/236 cam would run on 87 octane gas... must have fairly low compression ratio... which doesn't help the MPG...
Old 07-23-2013, 08:08 PM
I didn't catch that.
The system may have been retarding the timing, that hurts mileage pretty bad too.
Old 07-24-2013, 07:19 PM
. LOL! Yes, I didn't think of the computer retarding the timing from a knock sensor...
Old 07-24-2013, 08:35 PM
abrojal's Avatar
Quote:
tnx! Stock heads enginetech stage 1 cam
Danny Cabral, who has a 79 EFI 460, told me a lot about Terminator EFI
Fuel injected engines don't suffer from oversize throttle bodies like carbureted engines do,
because the fuel can always be properly metered to the amount of air entering the engine.
Fuel injected engines don't rely on engine breathing (venturi effect) for proper fuel metering.
The 700 cfm TBI throttle body has 1" bores, and actually flows about 650 cfm with the injector pod.
The 900 cfm TBI throttle body has 1" bores, and actually flows about 850 cfm with the injector pod.
The 950 cfm TBI throttle body has 1" bores, and actually flows 950 cfm because there's no injector pod.
Holley TBI units are CFM rated the same way as four-barrel carburetors - at a depression of 1.5 in/Hg.
(Two-barrel carburetors are rated at a depression of 3.0 in/Hg.)
Old 07-25-2013, 12:38 AM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
In to follow. Been looking at these as well.
Old 01-19-2014, 08:22 AM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
holley seems to be good system!
Been reading on these but ended up going with ezefi 2.0. Reason is cold start tunability. holley is catching up! they all have their place. My 2.0 showed up this week. working in colorado, sucks!
Old 01-19-2014, 09:50 AM
dimora's Avatar
There's an article featuring four systems head-to-head installed on a Nova in the March 2014 Car Craft. It's a great read!
It reviews:
MSD Atomic
FAST EZ-EFI 2.0
Edelbrock E-Street
After reading it all, I would choose the terminator because of the easy hook-up to my C-6 tranny kick-down linkage.
I would also use the article-recommended Aeromotive Phantom Stealth-340 based in-tank fuel pump setup.
Old 01-21-2014, 12:47 PM
Quote:
After reading it all, I would choose the Terminator because of the easy hook-up to my C-6 tranny kick-down linkage.
.. LOL! Your comment made me think of the new car commercials these days that try to get one to choose a new car based on the type of internet connectivity in it... what's our hobby come to...?!?!?
1997 f250 460 efi hambone460 1987 - 1996 F150 & Larger F-Series Trucks 2 03-13-2017 08:46 PM
Odometer decals? rmallow77 1947 and Older Ford Trucks 2 12-29-2016 05:50 AM
New pics of my 75 Truck eladnermai 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-16-2016 05:58 PM
Hey I'm new just picked up my first '48 Project1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 04-10-2012 06:50 PM
5.0 efi wiring 1954_5liter 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-30-2007 10:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
