Gas Mileage - Ford Truck Enthusiasts Forums
Gas Mileage
Old 05-20-2013, 04:11 PM
HBN's Avatar
HBN HBN is offline
HBN is starting off with a positive reputation.
Gas Mileage
Just curious what kind of mileage I should be getting. I have a 50 F3 with the 226 in it. Everything is stock, rear end, tranny, ect. Checked last week, and I was getting 7mpg. I thought that was a little low. Any thoughts?
Dave
Old 05-20-2013, 04:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
You must be drag racing away from stoplights, and driving like Johnny Speed Racer!
Seriously, that's poor mileage. Check your timing and carb settings. You should be able to get 12 or so.
Old 05-20-2013, 05:11 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
FWIW, when I was stripping the cab of my '49 F4 six cyl, I found where someone had obviously figured mileage on the dash with pencil. It came out at six MPG and I want to say four another time, about right for a truck that size worked off road or any kind of stop and go while loaded. I have no idea how the truck was being used when the mileage was figured. You should experience somewhat better while on the road and driven with skill. Stop light to stop light, maybe not. Be mindful that if you are running with today's traffic, that little six is turning some revs.
Old 05-20-2013, 07:03 PM
HBN's Avatar
HBN HBN is offline
Drag racing with this truck? Nah, nice slow take offs, wouldn't want anyone to miss me grinning from ear to ear while I'm driving. Timing is the weekends project, I suspect I'll improve a little after that.
Dave
Old 05-20-2013, 07:57 PM
FP's Avatar
FP FP is offline
FP has a good reputation on FTE.FP has a good reputation on FTE.FP has a good reputation on FTE.
Any idea what a Y Block should be getting?
Old 05-20-2013, 08:54 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Originally Posted by raytasch View Post
FWIW, when I was stripping the cab of my '49 F4 six cyl, I found where someone had obviously figured mileage on the dash with pencil. It came out at six MPG and I want to say four another time, about right for a truck that size worked off road or any kind of stop and go while loaded....
Remember, that truck had probably 1,500 lbs of hydraulics! I think an F-4 is significantly heavier to begin with.
Old 05-20-2013, 08:55 PM
raytasch's Avatar
Quote:
I am afraid to check Missy Green She does like to drink. Someday when I run out of things to do I will replace the power valve with one that comes in a bit later.
Old 05-20-2013, 10:08 PM
48ATOY's Avatar
48ATOY 48ATOY is offline
48ATOY is starting off with a positive reputation.
My 48 226
I think a got about 10-12mpg
now this year I put electronic points in
and replaced the vaccum advance
it feels like more power?
have not done a mileage check
Joe
Old 05-20-2013, 10:09 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Several years ago on the way back from the Carlisle Truck Show (a 3 hour drive) I got about 14 miles per gallon. I have a 239 Y-block. Now that was with real 100% gas, pre-ethonal. I don't think my odometer was 100% accurate either.
Old 05-20-2013, 11:39 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Bobj49f2 just took a long trip with his '49 F2 226 flat six. original truck.
You should PM him and ask his mileage. I wanted to say 6-8 but not sure.
Old 05-20-2013, 11:53 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
During the swan song of "Albatross'" 239 Y block, it got ten mpg in (moving) city traffic. Albatross is a '55 F500 and, at the time, it was running on seven cylinders. Turns out that the #6 cylinder head had a bad exhaust valve due to the cracks in the head casting.
I think that we're looking to either rebuild or part it out and move on. Some days you're just too close to the downwind side of the fan.
Old 05-21-2013, 06:53 AM
FP's Avatar
FP FP is offline
I have the 239 Y-block, and I don't think I'm getting over 7 mpg in town.
Old 05-21-2013, 09:55 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I was trying to figure out what I got for mileage on this trip. My speedometer doesn't work, I used my GPS to check my speed. I figured I put on about 440 miles. We filled up three times at about 10-12 gals per fill up. I left my home with about a half tank, filled up by Chris's house in Cary, IL. Pulled into Rob's on fumes and filled up in Normal and again in DeKalb. I figured I got about 10-12 mpg. My carb was acting up, again, and was pouring gas out of the top so that had to affect my mileage and I didn't get a chance to tune it up before leaving but it was running pretty good. I would think if I rebuild the carb, again, and gave it a tune up the mileage should be better.
We also have crappy reformualted gas in this area so that tends to affect our mileage plus eat away things like carburetor gaskets.
Old 05-21-2013, 11:39 AM
HBN's Avatar
HBN HBN is offline
Thanks Bobj49f2, your carb and mine soung like they could be twins.
Old 05-21-2013, 05:48 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
For what it's worth in my 55 Town sedan with 272 2V. When driving from Washington state to Prince Rupert on my way to Alaska. I got 15mpg. And it was loaded up in the back seat and trunk till it was full. As a daily driver once here I averaged about 8 to 10. And I always ran Premium Fuel. And would put octane booster in it about every other tank. (I wonder if the Canadian gas was that much better)? I drove her year round and the engine had never had a head off. Had well over 100,000 on it when I sold it and still running strong. The 223's I have had did about the same. (8 to 10 mpg. Never 15 ever). I don't know why this 272 did so well. I guess they are like girls. They may be all the same but some are just better than others.
chip to increase mileage running veggie? klindamood Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 10-03-2014 02:43 AM
Forgot name - clean it for better mileage Steve_250 1999 - 2003 7.3L Power Stroke Diesel 9 06-24-2014 11:30 AM
Why do bigger tires get worse gas mileage? nt Big John Hance 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 02-23-2013 05:24 AM
Fuel mileage thread. archangel 1999 to 2016 Super Duty 5 01-07-2013 10:23 PM
Low Power Low Fuel Mileage trsest1 Ranger & B-Series 5 10-29-2003 03:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
