Auxillary Input on a 2006 F150!! Better Solution??
First, let me start by saying this is not a question of where it is or how to get it, but rather a possible solution to install one into this truck. Let me explain what I have before the bashing starts .
I work at a Ford Dealer. Recently I replaced a 6CD radio w/ steering wheel controls in a 2008 Fusion with a Single CD player from a standard truck. They both had two connectors on the back of them. Long story short, installing the single disc player into the Fusion the steering wheel controls wouldn't work. BUT, reprogramming the ACM (radio) with the correct as-built data turned on the functionality of the steering controls on the single disc radio.
My conclusion is this, that MOST Ford radios are very similar and can perform the same tasks after being programmed to the current setup. The differences are going to be how many and which connectors are on the back. Generally, the only one missing is the SUBWOOFER if you dont have the Audiophile. Connector C290A contains all power, speakers, and such. C290C is the subwoofer. And C290B is the accessory input. Most trucks are wired for DVD and Navigation. Mine has one pluged in there with wires coming out, but i have neither of those options.
Anyway, I did some digging into wiring diagrams on the 2006 F150 (without the AUX IN) and the 2007 F150 (with the Aux IN) and found something surprising with the second 16pin connector C290B. The 2006-2007 connectors and pin locations are exactly the same, with the exception of 4 wires (pins 6,7,8,14) which of course are for the Aux in jack. Those pins are empty on the 2006 model. There is no CAN BUS lines used to control the input, like previously thought, on this setup. Haven't looked into 2004-2005 but I suspect they are similar.
The only thing that I see that needs to be done, is to buy some wiring with the connector pins attached and add an accessory jack to the already existing connector. Pretty simple. The next thing.. reprogramming the current radio to allow the auxiliary input. Using IDS, you can look and see if there is a programmable parameter for the AUX in, or you may have to change the as-built data. OR you could still swap in a 2007 radio. The AUX input jack doesn't have to be a ford one, just any one and you choose location.
The connector views and wiring diagrams i am referring to are available at my website, Aux Input on 04-06 F150 - ExpertsWrite
Before someone says "that connector has CAN BUS in it!!", those lines are going to the Navigation, DVD, or Satellite.
Anyone's input would be appreciated.
Since I have access to IDS, im thinking of trying it. I want to buy a through mount female coupler 3.5mm plug, install it somewhere convenient, buy an extension male to male to run to the radio, cut one end off, solder the correct connector pins to it, and install it into the connector. At least thats my idea!
Why don't you just get an auxilary adapter for the radio you need? That's what I did althought I have the audiophile unit with an aux button and I installed a 3.5mm jack right between the cigarette lighter and reverse sensor button. What you are thinking sounds kind of crazy to me. From what I've been reading lately the aux adapters are hard to find so you may just be better off getting an aftermarket radio. I'm probably going to get one eventually with navigation. But I'm good for now.
jkbrowne
1999 to 2016 Super Duty
01-09-2018 07:05 AM
keth Stor
1983 - 2012 Ranger & B-Series
01-30-2016 08:37 PM
KR-SD
07-24-2012 12:53 PM
lionhart
10-26-2005 09:46 PM
