Strange misfire problems 2006 F150 5.4 Triton - Ford Truck Enthusiasts Forums
Old 05-20-2013, 11:07 AM
Theplowboy Theplowboy is offline
Theplowboy is starting off with a positive reputation.
I have a F150 Lariot With the 5.4 Triton. It only has 80,000 miles on it and has a strange misfire sometimes. Sometimes when going down the HWY and you go to pass or floor the accelerator, it will go to missing and popping, and sometimes it will take right off like it is suppose to. I have no idea what might be causing this. It runs excelent most of the time until you floor it. the check engine light started flashing the last time it done this and now is staying lit up. Any help on this problem would be great. Thanks.
Old 05-20-2013, 11:35 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Replace the spark plugs ASAP or you will be replacing the cat converters as well.
Old 05-20-2013, 11:39 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
BLKSVT is starting off with a positive reputation.
I know on my Lightning, a bad COP will make this happen, supposedly they are really only good for 50k miles. As mentioned above I would change the plugs and check the COP's.
Old 05-20-2013, 11:41 AM
What about the coils too or just the plugs? What plug should i go back with. I have heard bad things about the two piece factory plugs and have also heard bad thing about the champion one piece replacement plugs. Has motorcraft corrected the issues with thier plugs?
Old 05-20-2013, 11:44 AM
BLKSVT's Avatar
I use NGK...Coil packs are pricey if you could find the one misfiring then you could do one...
Old 05-20-2013, 11:49 AM
just wondering what kind of plugs to go back with
Old 05-20-2013, 11:50 AM
BLKSVT's Avatar
NGK..................
Old 05-20-2013, 12:15 PM
Thanks for the help! I will try this and post back later Thanks!!!
Old 05-20-2013, 04:01 PM
I would stick with Motorcraft SP515. Put antisieze on the ground shield and they will come out pretty easy the next time u have to change them.
5.4 triton multi codes 05FordTough 2004 - 2008 F150 2 11-17-2014 08:23 AM
Misfire F-350 Went724 1999 to 2016 Super Duty 1 09-10-2014 05:53 AM
strange misfire problem f250d4x4 1997 - 2003 F150 5 12-11-2013 05:13 AM
Im stumped 5.4 triton stroken Modular V8 (4.6L, 5.4L) 6 03-30-2012 08:46 AM
backfire under load during aceleration myfav8 2004 - 2008 F150 6 03-31-2011 09:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
