1993 f350 spindle nut ID
Old 05-20-2013, 09:53 AM
Infinite Monkeys's Avatar
Infinite Monkeys
Infinite Monkeys is offline
Hi,
I'm in the middle of replacing the front rotors. I have the hub off and can see, what I think is the spindle nut. It looks like a round disk with 6 flat spots around the diameter. It appears to be screw on. Is this the spindle nut?
It's a 1993 F350, 4X4, HP Dana 60 and automatic hubs.
Thanks.
Old 05-20-2013, 04:18 PM
mpc07005's Avatar
mpc07005
mpc07005 is offline
6 Flats? Mine has 4 keys, and uses a standard D60 spindle nut tool. AZ has it for $20-$30. heres a pic of what's in mine. Is this what you have? http://i1241.photobucket.com/albums/...s/DSCN0567.jpg
-Mike
Old 05-20-2013, 05:28 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Here's a picture of my '95-97 Dana 60 axle. It is also a 4 slot spindle nut.
Attachment 293087
I believe the 6 slot spindle nuts were used on older generations of Fords along with all Chevy Dana 60 axles.
Do they look like the ones pictured in this post?
Looking for Dana 60 spindle nut lock washer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2013, 08:03 PM
Infinite Monkeys
It is not either one of the above. I called NAPA. They had the socket for $17.00. It is a 2 3/4" nut, but the nut has 6 flat sides and rounded edges. (hard to explain)
I'll put the socket part number up later for future refference.
Thanks for you help.
It's napa PT#: 776.9136
wezol5484
50
12-07-2013 10:42 AM
2500ak
04-26-2013 05:50 PM
dentsideranger
10-14-2008 06:37 PM
Jmudder79
Offroad & 4x4
20
06-05-2006 01:57 PM
69crewcab
05-10-2004 09:36 AM
Quick Reply: 1993 f350 spindle nut ID
