How big of tires can I fit on my F150?
Old 06-08-2003, 07:16 AM
Stingray42's Avatar
Stingray42
Stingray42 is offline
How big of tires can I fit on my F150? It is a 1984 Ford F150. I would like some big aggresive tires without a lift kit.
Thanks!
Andrew
Old 06-08-2003, 08:42 AM
msfprobass's Avatar
msfprobass
msfprobass is offline
I'm assuming your rig is 4wd since your wanting an aggresive tire. I've been doing alot of research on this lately, and this is what I've found:assuming your springs are not sagging too awefully bad and your using a factory 15X8 rim with normal offset you could use a 32x11.50 but I'm going to stick with a 31x10.50. The extra inch wasnt worth another 25-60/tire for me. I'm going with BFG all terrain TA K/O. It has a moderatly aggresive footprint but performs great on road or off and is a quiet riding tire. Depending on your needs the new Krawler series(BFG) is also a mean looking tire but be ready to pay( BIG). Hope this helps.
Old 06-08-2003, 04:40 PM
Stingray42's Avatar
Stingray42
2WD, I just want some bigger tires! What do ya think? The spings dont seem to be sagging too bad
Thanks
Andrew
Old 06-08-2003, 05:58 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
31x10.50's are about the limit up front on a 2wd, On my 82, I got some rubbing the radius arms at full lock, and some inner fender rubbing under full compression. On the rear, I've seen 33x12.50's fit without too much trouble.
Evan
Old 06-08-2003, 06:03 PM
Stingray42's Avatar
Stingray42
thanks!!!
Andrew
Old 06-08-2003, 09:07 PM
Aerodude's Avatar
Aerodude
Aerodude is offline
I agree 31's would be max on your truck.
Old 06-08-2003, 10:56 PM
Txquadhunter24's Avatar
Txquadhunter24
Txquadhunter24 is offline
31-10.50's all i can clear on the front of my 2wd F150, Can clkear a 35-12.50's on rear. Had to try the spare 35's of rear for kicks.
Old 06-09-2003, 06:10 AM
bluetruck81's Avatar
bluetruck81
bluetruck81 is offline
i have 33x 12.5 x15 size tyres on my 81 2wd, dont do it without doing some lift mods!! i put chunky mud tyres on mine and they wore quickly and rubbed on every part of the wheel arch possible.i am currently looking to lift mine so i can keep the tyres at that size, but without the lift spend your money more wiser and get a good 31 inch all terrain.
Old 06-09-2003, 10:26 PM
Stingray42's Avatar
Stingray42
I found some 32's, and measured them at 31 (real measurment) I have to go out tommorow and measure up on the truck! I did not buy, but will measure first. Only 200 bucks mounted (rims and tires) and fairly agressive, but rims have the clearcoat (?) peeling up. Still a good deal tho, just hope they will fit on my truck without rubbing!
Can you fix the peeling clearcoat (maybe oxidisation) ???
Thanks
Andrew
Old 06-10-2003, 05:00 AM
bluetruck81
only getting them sand blasted and then re croming them i think. dont quote me on that though. sounds like a good deal though,good luck.
Old 06-10-2003, 06:47 AM
bremen242's Avatar
bremen242
bremen242 is offline
i dont think 32's would fit on a 2wd, at least not very well. 31s are generally a bit smaller than an actual 31"s. when i was looking for bigger tires, all the tire shops around my house said 30x9.50's wouldn't rub. so i just said with 235-75's.
BigBlue92
2009 - 2014 F150
10-01-2016 07:44 AM
09f250hd
6.4L Power Stroke Diesel
34
02-28-2014 03:13 PM
cattlerancher
2004 - 2008 F150
07-13-2011 07:01 PM
flying scotsman
Offroad & 4x4
08-15-2004 02:56 PM
maxfordfan
07-17-2003 06:41 PM
Quick Reply: How big of tires can I fit on my F150?
