56 F100 D
#46
Build Update
Yes it has been awhile since I updated but until recently not a whole lot has been done except sanding cutting replacing and shaping. Slow process but the body is in progress of doing the final clean up steps getting bondo and primer. I will post as I move along and I hope to have it in paint by October!!!! Check out the pictures below.
Added the rear bed extension from MF rather than doing the roll pan with the rounded lower corners and also the tear drops.
Big back window panel from MF.
Bed getting smoothed out, finally
Down to metal and still a lot of little work left to do
PO'S attempt at hood repair
With the parts from MF this is the better way to accomplish hood repair. Nose skin will be welded in. All new under panel and end plates.
#47
#49
Nice job I am just started working on my 56 F100 I got every thing but have no time to work on it I'm feeling jealous I still have a long way, I'm upgrading the front end to Mustang II convertion kit from Performance on Line what do you think? it requires some welding but it comes with every thing brakes and steering rack ext.
#59
#60
Hey Jay,
Your truck looks great! I'm surprised that you didn't get more flash rust as you brought it down to bare steel as Ventura is right on the coast with fog.
Why are you putting it up for 6 months? You are so close.
Are you planning to paint it in your garage? I'll look for you driving around when I'm out in Santa Barbara in March.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
