1994 Ford F Super Duty 460 problem - Ford Truck Enthusiasts Forums
Old 05-18-2013, 11:12 PM
shawbran shawbran is offline
shawbran is starting off with a positive reputation.
I'm in the process of putting new exhaust manifolds on my farm truck. Tonight I was getting ready to install the drivers side and noticed that the dipstick tube was loose at the oil pan. Upon further inspection I noticed that the previous owner had siliconed the dipstick in place. The pan was a obvious spot for it. There is a o-ring on the bottom of the tube where it goes in the pan. I went to Oreilly's thinking maybe the oring was bad. They can not find anything on saying that this should be a pan mounted dipstick tube. Does anyone have any information to help me out??
Oil Leak at Base of Dipstick Tube/1989-460 TobaccoBarn460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 02-10-2016 08:56 AM
351m dipstick issue bobs 80 f250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-15-2015 08:20 AM
Is An O-Ring Required At Oil Dipstick Tube-To-Oil Pan On 460's? TobaccoBarn460 1987 - 1996 F150 & Larger F-Series Trucks 2 01-19-2015 12:10 AM
Leaking Dipstick Tube JD_F250 6.0L Power Stroke Diesel 3 10-27-2014 07:33 PM
Dipstick tube problems!!! JWAbercrombie 1999 - 2003 7.3L Power Stroke Diesel 5 05-16-2013 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
