Changing cap, rotor, wires
Just changed cap and rotor today but did the big no no of taking all the wires off at once.. Of course I still have the diagram showing how they hook up to the cap but the cap isn't centered like it is on the diagram.. So if I don't hook them up right will I be okay to try and start the truck to test it
1-3-7-2-6-5-4-8 is the HO firing order, which 5.8's had and what your '96 5.0 will have. Remember, this order is COUNTER-clockwise.
Looking straight at your engine your cylinder's are numbered like this
----- <- fire wall
4 8
3 7
2 6
1 5
O <- distributor
Just wire it up using the firing order and you will be okay. However if you don't know which one to put number 1 spark plug wire on, take #1 plug out and stick your thumb/finger over spark plug hole. Bump the starter over until you feel pressure on your finger. That should be TDC on the compression stroke of cylinder number 1, look at your rotor and whichever post it's pointing to on your cap, that should get #1 plug wire and then just go counter clockwise from there. That's what I would do if there was no indicator on the cap for which one is 1.
----- <- fire wall
4 8
3 7
2 6
1 5
O <- distributor
