Overheating - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Overheating
Old 05-18-2013, 05:03 PM
Kyle799's Avatar
Kyle799 Kyle799 is offline
Kyle799 is starting off with a positive reputation.
Cool Overheating
What temp should this truck run at?
Also i am getting error code p0480 for Fan 1 Control Circuit
Recently replaced the fan clutch and thermostats.. where do i start looking for this problem?
Old 05-18-2013, 07:15 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Check the sensor for the fan and its ground. 194F is normal operating temp...unloaded.
Old 05-18-2013, 08:12 PM
Kyle799's Avatar
OK thanks check which sensor/where is it?
Old 05-18-2013, 08:22 PM
senix's Avatar
Right at the fan, on top of the shroud. I would start there.
Fan Clutch Wiring KRDiesel 6.0L Power Stroke Diesel 19 09-19-2015 12:01 AM
Electric Fan? For 04' 6.0 calvinbabb 6.0L Power Stroke Diesel 32 11-19-2014 01:27 PM
Fan clutch bolts steve340 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-06-2014 12:54 PM
Fan, fan shroud and fan clutch part numbers steve340 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-10-2014 08:20 PM
Fan motor noise aka rotten 2004 - 2008 F150 0 09-30-2013 09:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
