FACTORY OR AFTERMARKET SKID PLATES?
Old 05-18-2013, 02:02 PM
defiantoutlaw's Avatar
defiantoutlaw
defiantoutlaw is offline
Did 73-79 f-250's come with factory skid plates? ....is there a decent aftermarket set out there available?
thank you.
Old 05-18-2013, 04:52 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
You mean OEM skid plate for the axles, trans and xfer case? I do not think so, just hang on number dummy will probably chime in with some blast from the past diagram.
For front and and rear axles aftermarket wise, there was a old company called "Go-Rhino" outa Cali that years ago sold a bolt on pumpkin skid plate and axle truss in one.
Some folks called them a trail marker cause it actually lowered your axle clearance and made drag marks every where you went.
I am sure there are some rock crawling type business that will sale just a bolt on ring and pinion/u joint protection collar, as well a HD dif cover.
Differential Covers & Armor - RuffStuff Specialties
http://www.google.com.ua/url?sa=t&rc...Jkm_EsNnsdhYQw
Old 05-18-2013, 11:57 PM
defiantoutlaw
Thanks for the heads up. I may be fabricating a few pieces.
Old 05-19-2013, 03:07 AM
77&79F250's Avatar
77&79F250
Here I found a few pics of those crazy Go-Rhino skid plates....not my truck BTW.
Same design for the rear, just webbing on both sides.
Maybe get a few old transmission cross members and mod them into skid plates?
Old 05-19-2013, 08:03 AM
teds74ford's Avatar
teds74ford
teds74ford is offline
Here's a skidplate I made for the transfer case on my old truck:
Dom165
1999 to 2016 Super Duty
01-26-2016 12:12 PM
Linemo
12-21-2009 05:39 AM
98infinity
1997 - 2003 F150
05-17-2007 11:13 PM
Broke_Okie
11-14-2005 12:10 AM
NoMo
03-16-2002 07:15 AM
Quick Reply: FACTORY OR AFTERMARKET SKID PLATES?
