"Change oil soon" message
Old 05-18-2013, 01:44 PM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
For the first time since I bought the truck, I'm getting the "Change oil soon" message. With DEF, you know how many miles you've got left before the system starts to shut the truck down to some extent. I can't find anywhere in the manual/supplement how long it's safe to drive before changing the oil.
Are you given enough warning to drive a few hundred miles, or is the need immediate? Does anyone know?
Old 05-18-2013, 02:35 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
Yes it's safe to drive for a bit after that message. The oil isn't going to instantly decompose and break down into sludge. Oil change intervals are always very conservative.
The 'Oil Change Soon' message will change to 'Oil Change Required' later on. So, just take the nearest opportunity to pick up a FL-2051S and 13L of 0W-40 or whatever you want to use.
Old 05-18-2013, 03:41 PM
kper05's Avatar
kper05
kper05 is offline
I think it's within 500 miles where it will then report the 'change oil required.'
It won't disable the truck but it does need to be changed.
Old 05-18-2013, 04:47 PM
tolliewolly's Avatar
tolliewolly
tolliewolly is offline
Agreed with the guys above. It's not going to kill the truck I'm sure. Just get it changed when you get time.
Old 05-18-2013, 04:51 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is online now
Received 1,447 Likes on 893 Posts
MPNX2
2017+ Super Duty
13
08-26-2018 12:43 PM
Texaswilliam
2017+ Super Duty
07-23-2018 07:39 PM
wfedwar
2017+ Super Duty
08-10-2017 07:30 PM
KPT
6.7L Power Stroke Diesel
06-13-2013 07:27 AM
blueheron
05-24-2011 08:33 PM
Quick Reply: "Change oil soon" message
