Upper Control arms...alignment? - Ford Truck Enthusiasts Forums
Old 05-18-2013, 12:19 PM
JoSHN JoSHN is offline
JoSHN is starting off with a positive reputation.
I just replaced the upper control arms on my 08 Scab as both ball joints were absolutely shot. Can anyone explain to me though, why my repair manual says to get an alignment done after replacing them?
I know on the older f150s there was a torsion key on the control arms that you adjusted to correct your alignment or sometimes level your ride (with aftermarket torsion keys), but the new trucks simply have a pivot bolt on both sides and a ball joint.
So why the need for an alignment?
Ball joints sam hain 1997 - 2003 F150 3 01-01-2017 10:31 AM
Lower control arm removal question keyul 1997 - 2003 F150 2 10-24-2016 11:11 PM
Recent Volare IFS Parts List and Notes 56-BW 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-31-2015 12:26 PM
Lower control arm replacement 97' f-150 4x4 mcgowen980 1997 - 2003 F150 2 11-02-2014 02:28 PM
97 Explorer 4WD upper ball joint pete315 Explorer, Sport Trac, Mountaineer & Aviator 7 08-06-2009 11:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
