EGR cooler questions
I have a 2003 Excursion and am getting moisture on the EGR valve and coolant spewing out the small return hose. I filled the degress bottle to the high mark and drove about 200 miles and it was down to the low mark. The only thing i can think of is the cooler. I have posted other threads about delete kits and another motor being put in due to hydrolock in the last couple of years but am still having issues. i am looking at jumping in and pulling egr cooler today and testing it as best as i can. talking to a member last night we decided this is best then order full delete (thanks toreador).
so my questions are:
1. how can i remove the egr cooler without pulling intake manifold
2. where is the cheapest delete (no need to worry w/cel)
3. what gaskets, o-rings, seals do i need to order w/delete kit
i spent several hours last night looking here and there and got overloaded w/info so i am asking for help.
thanks,
Levi
thanks,
Levi
I have a 2003 Excursion and am getting moisture on the EGR valve and coolant spewing out the small return hose. I filled the degress bottle to the high mark (You should only be filling it to the low mark. If you fill to the high mark it will puke everytime) and drove about 200 miles and it was down to the low mark. The only thing i can think of is the cooler. I have posted other threads about delete kits and another motor being put in due to hydrolock in the last couple of years but am still having issues. i am looking at jumping in and pulling egr cooler today and testing it as best as i can. talking to a member last night we decided this is best then order full delete (thanks toreador).
1. how can i remove the egr cooler without pulling intake manifold Remove the turbo, turbo braket, and loosen all intake bolts. That's the only way I know to do it without removing the intake, but IMO might as well remove the intake at that point so that you can clean it really good.
2. where is the cheapest delete (no need to worry w/cel) Do some searching. There are a ton of kits on the market. Not sure who is cheapest, but look into sinisters basic delete.
Turbo install kit is the only thing I can think of that you will need other than the delete kit
thanks,
Levi
thanks,
Levi
I would also add that if you do have egr cooler problems, it is highly recomended that you change the oil cooler at the same time. I would flush the coolant system really good with VC9, install new Oil cooler (will require complete removal of intake), and install new Bullet proof diesel egr cooler (what I recomend) or egr delete
Ok folks, I got the cooler out. Not a terrible chore but not a cake walk either. Ordered a delete and coolant filter setup, but I have another question. When I put all this stuff back together, do I need to replace o-rings on turbo as well as the seal for the oil line on top of the turbo? If so, what is the kit called and who has them. Thanks again for the help and if you could rep snuggyworm for his 45 min convo today over the phone helping me out.
Sorry for the late reply on the issue. I got the delete kit put in Thursday evening and in my rush to get it done I broke the coolant return nub off so pulled the radiator out and had it drilled/tapped and a metal barb put in. Put that back on and filled it up with ELC and some ATF for the tranny and so far so good. I also installed a coolant filter and the verdict is still out on that but for now, let the good times roll.
thanks again for all the help.
