1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
02 F250 Super Duty 5.4
Old 05-17-2013, 09:58 PM
rays1205's Avatar
rays1205
rays1205 is offline
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--> Out of the blue my temp gauge pegs hot and engine appears to flood badly. The engine is not hot at all; my scanner says 1299 code for head heat protection? Strangely enough you could simply turn the key of and back on and the temp gauge returns to normal and runs good.
It is progressively getting worse! I have found that if you accelerate quickly it run fine however at an idle it now lopes badly?? Any Ideas??
Old 05-18-2013, 06:15 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Check your coolant level to make sure that it's filled as an air bubble under the CHT will cause it spike the temp reading. If the coolant level is good and the system doesn't have air in it, replace the CHT.
pablocruz69
1997-2006 Expedition & Navigator
01-04-2018 05:20 PM
hornychief
1997 - 2003 F150
01-28-2014 08:23 PM
Btoddsmith
6.4L Power Stroke Diesel
23
03-20-2013 09:39 PM
Schlominator
07-05-2012 12:41 PM
jcollsn86
1997 - 2003 F150
08-06-2008 01:55 PM
Quick Reply: 02 F250 Super Duty 5.4
