2004 f150 4x4- how to flush transmission? - Ford Truck Enthusiasts Forums
Old 05-17-2013, 06:20 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
I have a 2004 Ford F150 4x4 with 170,000 miles. I am wanting to flush the transmission and refill it. The local quick lube wants $150. Is it just as simple to do it myself and save the cash?
Old 05-17-2013, 06:49 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
Why would you want to flush it over a simple drain and refill?
Old 05-17-2013, 07:30 PM
I guess thats another question I need answered. when you get your oil change they always try and push the flush on you. but my father has the 07 model and his transmission was slipping a little and shifting hard other times (in his words). he had his flushed and says he hasnt had any more problems out of it.
Old 05-17-2013, 07:36 PM
JWC 3's Avatar
JWC 3 JWC 3 is online now
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I would not reccomend a flush at those miles unless it has been rebuilt recently . You may cause problems . Just drain and refill and change the filter . I have seen issues with trans and engine flushes . I don't like either on anything with those miles .
Old 05-18-2013, 03:03 AM
The only tie I've EVER heard that it was a good idea to flush a trans was from the guy trying to sell it to you,...
Old 05-18-2013, 10:33 AM
442w30 442w30 is offline
442w30 is starting off with a positive reputation.
My 08 4x4 has 195,000 miles on it and I flush the trans every 30 k with out cleaning chemicals. Its my understanding that if the trans has not had regular service you do not want to flush as this will dislodge sludge etc which could cause problems with trans. If little or no service it is best to just drain and fill. IMHO.
Heater core flush waldreps 2004 - 2008 F150 3 12-27-2016 08:17 AM
Transmission flush brent1204 2009 - 2014 F150 10 02-10-2014 01:20 AM
Coolant flush before or after oil cooler replacement loopsy 6.0L Power Stroke Diesel 9 04-15-2011 12:59 PM
2004 f-150 4x4 transmission problems Snowbelle 2004 - 2008 F150 0 03-06-2008 06:28 PM
Transmission Flush to Cure Vibration KTim 2004 - 2008 F150 7 09-05-2007 01:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
