wont start - Ford Truck Enthusiasts Forums
wont start
Old 05-17-2013, 12:43 PM
1997fordf350 1997fordf350 is offline
1997fordf350 is starting off with a positive reputation.
wont start
hi when i turn my key a whining usually comes on and now it doesn't and it wont start. all it makes is a click and that's it. everything else works fine.Thanks
Old 05-17-2013, 10:31 PM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
it may be helpful to know what type of vehicle you are working on.
make, model, year, ect.
if we assume you are working on a 1997 F350, then a whining sound may indicate the fuel pump. it should kick on for a second when you turn the key on. if it is not doing that, then you have something wrong in the fuel system. be it a failed fuel pump, or fuel pump relay being the most common (in my experience).
sometimes you can get enough pressure out of a failing (failed) fuel pump to start the vehicle if you cycle the key on/off about 10 times in a row then immediately try to start the vehicle. sometimes it will run for a few seconds that way.
alternatively, have some one bang on the bottom of the fuel tank while you cycle the key then try to start. sometimes they will run for a few seconds after doing this as well.
both of these would indicate, to me, a failed fuel pump.... assuming you have a fuel injected truck.
Old 05-18-2013, 11:54 AM
Ok. I took it into a repair shop to get it looked at. Thanks
HELP TRUCK WONT START Mamma Bear 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 06-09-2012 06:52 PM
Won't start MustangGT221 1987 - 1996 F150 & Larger F-Series Trucks 4 09-11-2002 12:55 AM
'94 explorer won't start dcexplorer Explorer, Sport Trac, Mountaineer & Aviator 4 09-04-2002 05:54 PM
Wont start DrFord Ford Inline Six, 200, 250, 4.9L / 300 2 09-14-2001 07:57 PM
truck won't start Phillip Guidry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-20-2000 09:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
