Coil packs - Ford Truck Enthusiasts Forums
Coil packs
Old 05-17-2013, 06:50 AM
ghcat ghcat is offline
ghcat is starting off with a positive reputation.
Coil packs
I have a 2001 Expy with 225,000 miles and just had #4 coil replaced a month ago. Now #8 is miss firing. In the past I have replaced 1 and 6. Do I need to replace all the others while we are doing #8 or is it just one of those things?
Old 05-17-2013, 07:40 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Your choice. You can either replace them all preemptively as an attempt at preventative maintenance or one at a time as they fail.
You'll get advocacy of each course of action but it will ultimately be your decision.
Old 05-19-2013, 06:12 AM
JWA's Avatar
JWA JWA is online now
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Agreed ^^^ and the other thing will be which brand to use. Reading here I've seen too many instances of aftermarket COP's failing, my own experience with Granatelli says stick with Motor Craft or Standard Motor Products. Prices have come down to about $45 each from the various online parts sellers, probably find a similar price in your local outlets too.
Over three different E250's I've bought used (2 with 200K + miles) there's not be a single COP failure----I strongly recommend OEM all the way!
Old 05-19-2013, 02:14 PM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
stephen.osborne1 is gaining momentum as a positive member of FTE.stephen.osborne1 is gaining momentum as a positive member of FTE.
One thing to consider as well, is that more often than not, the COP itself has not failed, but the boot has rotten or torn, causing the spark to cross the tear into the exposed head instead of the plug, thus causing a misfire. Some auto parts stores carry the boot, which can be replaced alone (at about $5 apiece). Not always the case, but can be a much cheaper fix.
Old 05-20-2013, 08:58 AM
JWA's Avatar
Quote:
Good idea--NAPA carries a USA made Belden boot/spring package p/n #702418 for about $5 each!
Be sure to use a dab of dielectric grease in the plug and COP end, helps seal them.
How do i test my coil packs to see if there weak? 02 Super Duty Guy 1999 to 2016 Super Duty 5 03-12-2014 09:25 AM
coil arching 410F-100 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-18-2012 06:25 AM
Anybody else running a BWD Select ignition coil for their 5.8? DBGrif91 1987 - 1996 F150 & Larger F-Series Trucks 0 03-20-2011 05:28 PM
Expedition Electrical Coil xtmsports 1997-2006 Expedition & Navigator 7 06-21-2010 03:45 PM
ignition coil replacement f1501988 1987 - 1996 F150 & Larger F-Series Trucks 1 04-22-2006 10:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
