Yep, simple question, but you might get lots of different answers.
I prefer the bench seat, but I'm more of a stock guy. I always have preferred a bench seat.
What are your plans for the truck? Maybe guys can show you some pictures of what they have. (My seat is a frame sitting on a shelf.)
I like buckets, but that limits you to 1 passenger, a bench seat is not as comfortable but allows you to carry two other people. The compromise is a split bench.
i'm having the same issue… especially since i want a center console… i could do a half console with a bench. but then with the seat back. the air duct cover would show. as the a/c unit will be located behind the seat…
Just had the same self conversation in the fall of last year. Ended up splitting the difference like someone mentioned above - 60/40 split with a fold down center armrest w/storage inside.
Unless you go to a smaller steering wheel, and a column mounted automatic shifter, you're not going to want to drive around with 3 adults in the front after trying it once. It's about the same width as a Ranger.
