Planning a swap to manual transmission. Suggestions?
Okay I have a 90 F-150 302 with an aod tranny right now. Planning on when the tranny goes to swap to a manual. Always wanted one but couldnt find a truck at the time. Was wondering suggestions on best tranny to use and so on. I understand I'll have to swap column. Install clutch, punch out floor for stick shift and maybe a crossmember swap. Plus other small things. If anyones got a link to a forum where someone did on my model truck I'd appreciate it! I like a challenge haha. Was originally planning to swap from 2x4 to 4x4 and manual but I have been fine this past winter even with a few bad storms. Also 3.73 rear end I believe.
You need the entire pedal assembly, as it is one unit. I would consider the best transmission to use the ZF5, which is an overdrive transmission used in 3/4 ton and bigger trucks. I'm not sure what year they began installing them from the factory, but its the only aluminum transmission available in the 3/4 ton and bigger trucks.
on
So the pedal assembly is e-brake and clutch?
The ZF5 trans would be best if you can find one but the Mazda is much more common. The ZF5 and M5OD were both used starting in 1988.
Don't settle for the M5OD. The ZF transmission is superior and just as common, as it came in 3/4 ton and larger trucks as the only manual transmission choice after 1987 (for the most part anyway, I have seen a handful of M5OD trannies in 3/4 tons but they were all light duty). Make sure that you get one for a small block though, as the bellhousing does not separate like garthneddy said.
you will need to change the flywheel and spacer plate on the 5.0 if you use the ZF5 trans- that trans was used on the 4.9 and 5.8 which both used the 164 tooth flywheel, the 5.0 uses the 157 tooth flywheel. You WILL need to use a 164 tooth flywheel that has the proper balance for the 5.0 otherwise the starter will never engage the flywheel properly.
