A couple of vins/warranty plates i need decoded - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-16-2013, 06:15 PM
Dieselzuk Dieselzuk is offline
Dieselzuk is starting off with a positive reputation.
I am looking for a 5 spd with OD trans mission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is
F60ccdk2492...trans code 4
The second one is
F61ecx41510...trans code 0
Thanks for all the help!!
Old 06-05-2013, 12:30 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Dieselzuk View Post
I am looking for a 5 spd with OD transmission from a 79 'ish F600..I have came across 2 trucks..but not sure if they have od.
The vin for the first is F60CCDK2492...trans code 4 / The second one is F61ECX41510...trans code letter O
F60 = F600 2WD / C = 370 2V or 429 4V (both listed under C) / C = Oakville Ontario Canada Truck Assembly Plant / DK2492 = 1979 / 4 = Clark model 280VO 5 Speed Overdrive.
F61 = F600 2WD / E = 361 2V or 4V FT engine / C = Oakville Ontario Canada Truck Assembly Plant / X41510 = 1977.
O refers to two different 5 speed transmissions: Fuller model T905B 5 Speed Direct or New Process model 542FL 5 Speed Direct.
Old 06-05-2013, 03:58 PM
Thank you sir!
1956 F250 OD Trans identification bmann52 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 05-27-2014 08:59 AM
1966 F 100 vin decode littsen1 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-14-2013 08:36 PM
F600 VIN decode? tinman52 Large Truck 3 08-03-2012 01:06 PM
VIN numbers ? amsvage 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-18-2005 02:20 PM
E4od Eric 1987 - 1996 F150 & Larger F-Series Trucks 3 06-17-1999 11:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
