2000 V10 Spark Plug Question - Ford Truck Enthusiasts Forums
Old 05-16-2013, 03:05 PM
Ajlowry Ajlowry is offline
Ajlowry is starting off with a positive reputation.
Hey everyone! Let me just say this is my very first post to FTE! I just bought a 2000 Ex Limited with the 6.8L engine. Has 93,000 miles and I'm going to do the plugs this weekend. I got the motorcraft iridiums and I've read in 2 different places to use anti seize and to not use anti seize when you put the new plugs back in. Seems like all the V10 posts say to use anti seize on the new plugs. I read some posts on a 5.4L saying not to use anti seize. What have ya'll done with the 6.8L when replacing the plugs? Thanks in advance!!
Old 05-16-2013, 03:19 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Do it either way, I don't use it myself and I use the regular plugs. Don't forget new boots!
Old 05-16-2013, 03:25 PM
Quote:
Thanks EXv10! Yea I got the boots too. Not looking forward to the back right plugs (looking from drivers seat). I'm a short guy so I'll be sitting on the engine practically!!
Old 05-16-2013, 04:51 PM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Yes to the anti seize, just a dab of the good silver stuff on the plug threads. Don't over do it.
Old 05-16-2013, 04:58 PM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Welcome! Yes use anti-seize and check your torque. Take your time with as few interruptions as possible.
Old 05-16-2013, 05:41 PM
sammie0126's Avatar
Here is a "how to" if you need step by step
http://www.ford-trucks.com/forums/12...-pictures.html
Old 05-16-2013, 06:35 PM
I've always said anything you put on the plugs is going to upset the torque value. I use regular plugs and change them sooner. I'm not a fan of "extended life" products. These plugs can strip out those early model heads with the combination of anti seize and "getting it plenty tight".
http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
Should Spark Plugs be Installed with Anti-Seize Compound?
Old 05-16-2013, 07:15 PM
az_r2d1 az_r2d1 is offline
az_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud ofaz_r2d1 has much to be proud of
Make sure to use a torque wrench.
Without it you will either strip the threads or the plug will come out.
These engines/years had issues with plugs coming out.
I'd also use regular motorcraft plugs. nothing else.
Old 05-16-2013, 07:23 PM
Autolites are the same thing, and I never torque mine. There is a fine line between too tight and too loose with these due to the tapered seat. I also like the regular plugs.
Old 05-16-2013, 09:36 PM
Thanks everyone. Sammie0126 that's a great tutorial!! Think I'm gonna stick with the standard motorcrafts and use just a small amount of antiseize. Seems like the majority of posts I've read suggest to use it.
Popped out a spark plug 03prerunner Excursion - King of SUVs 7 08-26-2014 04:35 PM
Spark Plugs 460ci - To Ani-Seize or NOT to Anti-Seize...that is the question? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 5 04-14-2014 06:13 AM
89 Inline 6 Spark plug Question Jlckb5 1987 - 1996 F150 & Larger F-Series Trucks 16 01-17-2012 05:00 PM
Anti-seize on glow plugs panningbros Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-12-2011 02:17 AM
Spark Plug Confusion paul Modular V10 (6.8l) 16 04-02-2008 08:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
