Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Things to look for in 99-04 Lightnings?
Old 05-16-2013, 01:44 PM
obsidianspider's Avatar
obsidianspider
obsidianspider is offline
While taking a look at the used trucks for sale in the area I've seen a few Lightnings popping up, but most of them have over 90,000 miles. I've got very limited supercharger experience, so is there anything I should look on one of these higher mileage engines? What's the typical life of a factory supercharger before it needs to be serviced?
Old 05-19-2013, 12:49 PM
stoffer's Avatar
stoffer
stoffer is offline
look for signs of removed mods
if it's been pullied it needs to come with a tuning device
no WOT shifts into OD, no two-gear kickdowns
if the supercharger has been ported then the oil has been changed, now if it's been run with conventional oil VS supercharger oil then it'll need to be changed every 5k miles or so just like the engine oil
Old 05-19-2013, 01:01 PM
obsidianspider
Thanks. This is the kind of stuff I was hoping to hear.
I read that the 03-04 models are the ones with the better heads so they don't have the plug spitting problem. Hopefully that's accurate.
Old 05-19-2013, 05:23 PM
stoffer's Avatar
stoffer
stoffer is offline
any two valve head that has an improperly torqued spark plug can and will spit the plug regardless of threads in the plug boss
King0581
09-14-2011 05:49 PM
jd1083
1999 to 2016 Super Duty
07-12-2011 12:13 AM
WestCoastTodd
05-25-2011 02:18 PM
mephrey
1997 - 2003 F150
02-04-2008 08:04 PM
chsw
3.0L V6
09-21-2005 07:08 PM
Quick Reply: Things to look for in 99-04 Lightnings?
