1966 Tailgate - Ford Truck Enthusiasts Forums
1966 Tailgate
Old 05-16-2013, 12:11 PM
Gwol's Avatar
Gwol Gwol is offline
Gwol is starting off with a positive reputation.
1966 Tailgate
How do I remove the tailgate on my 1966 F100?
Old 05-16-2013, 01:08 PM
Gcwstang Gcwstang is offline
Gcwstang is starting off with a positive reputation.
You have to remove the two bolts on the bottom of both sides of the tailgate and comes out carefully
Old 05-16-2013, 02:42 PM
old broke prospector old broke prospector is offline
old broke prospector is gaining momentum as a positive member of FTE.old broke prospector is gaining momentum as a positive member of FTE.
a bit more detail..... lower the tailgate, raise the support arms and raise the tailgate until you can disconnect the support arms from the tailgate, they line up for removal without removing bolts.
You only have to remove one side, top and bottom, the top with the tailgate open and the bottom with it shut.
After removing the 2 bolts on one side, lift that side of the tailgate and it will come loose easily from the other side.
Old 05-16-2013, 05:48 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
I agree, a Piece o cake.
John
1966 wide bed tailgate: leonharu 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-06-2015 06:35 PM
1966 FORD BRONCO TAILGATE ADJUSTMENT SAM ROYE 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-26-2014 02:59 AM
67-72 tailgates does it fit on a 1966 F100 topscrt 1961 - 1966 F-100 & Larger F-Series Trucks 8 07-11-2009 04:11 PM
1963 ford f100 tailgate choctaw1 1961 - 1963 F100 Unibody 12 04-27-2009 11:37 AM
Tailgate differences? jcs1966 1967 - 1972 F-100 & Larger F-Series Trucks 6 03-07-2003 11:16 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
