1979 Ford 7000 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1979 Ford 7000
Old 05-16-2013, 02:03 AM
stroker79 stroker79 is offline
stroker79 is starting off with a positive reputation.
1979 Ford 7000
I have a 1979 Ford 7000 I am fixing up and was wondering if anyone knew where I could find a turn signal/flasher switch (the one in the steering column) and a the plastic radio bezel? or even a radio set up that will mount where the factory AM one is? Thanks in advance for anyone with information....this is a great site and has helped me a lot over the years!
Old 06-08-2013, 06:53 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by stroker79 View Post
I have a 1979 Ford 7000 I am fixing up and was wondering if anyone knew where I could find a turn signal/flasher switch (the one in the steering column).
Away 5/16-5/30 (BC/Yukon/AK), playing 'catch up' ever since.
E1HZ-13341-D (replaced D1TZ-13341-A) .. T/S Switch-Use without T/T (Tractor-Trailer) / Obsolete
Applications: 1971/84 F500/880. F7000 is an F700 w/a diesel engine and I assume it's not a tractor w/a trailer.
BOYER FORD TRUCKS in Minneapolis MN has 1 = 612-378-0460.
POECS PARTS in Erie PA has 6 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959/513-731-3304.
MILLER OBSOLETE PARTS in Binghamton NY has 18 = 607-722-5371.
1979 f150 radio wiring spookypooky 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-10-2016 10:21 AM
Factory radio problems Josh726 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-09-2015 07:39 PM
looking at buying a ln7000 input deck60 Large Truck 2 09-24-2014 09:54 AM
Can I swap a 2008 radio with a 2012 radio? Shaun Fed Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 06-14-2014 01:36 PM
1979 F150 am radio ...Looking for Am / FM Radio conversion GOLFER1ESS 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-06-2014 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
