Extreme grinding in tranny - Ford Truck Enthusiasts Forums
Old 05-16-2013, 12:08 AM
no1highpockets no1highpockets is offline
no1highpockets is starting off with a positive reputation.
Hi guy's. New here, was looking for a place to get some info.
My Dad has a 01 f150 xtended cab 5.4 auto. Some of this info is second hand. He had driven it on a trip about 50 miles,when he started it to return he said it did not want to engage, put it in gear and nothing happened. Messed with it a bit and got it to go. was fine for about 30 miles or so. Then it started to make noise. I trailered it home and drove it a couple hundred yards to the shop. It sounds like a very large, very dry bearing, also seemed to catch/lock up then clunk. With the wheels off the ground you can kick it into neutral and while the wheels are still rolling it quiets down. Also it does it sometimes while in neutral. When it is in park it sounds like stuff is still turning. At fist I thought wheel bearing or rear end until it made noise in neutral and park. The noise in park is not loud, just sounds like things are turning. It is full of fluid. The tranny has always worked flawlessly and still does even with the noise. Any idea where to start looking? Transfer case? TIA
Old 05-16-2013, 01:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I'd start looking with a mechanic's stethoscope to see just where the noise is coming from.
Does this truck make my rearend look big? Ranger Bob Modular V8 (4.6L, 5.4L) 3 10-16-2013 10:07 PM
Bad bearing noise, can't figure it out. rad1026 Explorer, Sport Trac, Mountaineer & Aviator 12 08-19-2013 03:06 PM
Mysterious Knocking/Tapping Sound From Engine or Torque Converter Contingen-Sea 6.0L Power Stroke Diesel 6 09-06-2011 03:24 PM
Would a blown cv joint cause this? flyhound Clutch, Transmission, Differential, Axle & Transfer Case 1 11-29-2010 05:15 PM
intermittent high pitch noise Mr.Russell 2004 - 2008 F150 2 08-07-2008 11:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
