223 3-speed to 300 3-speed swap
Old 05-15-2013, 09:44 PM
drewduncan15's Avatar
drewduncan15
drewduncan15 is online now
Any idea if the 300 would bolt up to my 3 speed? its a 1954 f100. not sure what the 300 is out of. how tough would this swap be
Old 05-15-2013, 11:10 PM
Bozworth's Avatar
Bozworth
Bozworth is offline
There's a lot of great options for transmissions that match the 300. C4, C6, AOD, and mine has the SRO-RUG. It just seems to me that you would lose some of the benefits of the 300 by mating it to your old sideloader. I want to say it takes a non-standard and expensive bellhousing to get that done, but i'm not sure. I can't remember where I saw that.
I'm in the process of putting a 300 in my 54. It's not a bolt in swap, but it's not too complicated either. You'll need an aftermarket crossmember, about $120. And possibly new motor mounts, but it depends on what year your 300 is. Is it EFI or carb'd? (EFI wasn't introduced until '87)
Head over to this forum and do some searching...I think you'll get your questions answered.
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
Good luck with your swap!!
Old 05-15-2013, 11:50 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
[quote=Bozworth;13166486]There's a lot of great options for transmissions that match the 300. C4, C6, AOD, and mine has the SRO-RUG. It just seems to me that you would lose some of the benefits of the 300 by mating it to your old sideloader. I want to say it takes a non-standard and expensive bellhousing to get that done, but i'm not sure.[ /quote]
Yeah. I would do a ZF 5 speed with a 300...
Old 05-16-2013, 08:48 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The 300 has the same bell housing bolt pattern as the small block Ford. Find an adapter bell housing to go from the small block bolt pattern to the three speed bolt pattern. You will have to do some looking since these are out of production, but they are out there.
Old 05-17-2013, 08:43 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Since you already have the clutch pedal and linkage I would suggest that you loose the 3 speed and install a 5 speed . Then you get the advantage of Overdrive .
Col Flashman
08-20-2013 07:24 PM
my64f100
05-31-2011 12:25 AM
HT32BSX115
04-13-2006 12:39 AM
97F250LD
12-03-2003 09:44 PM
trouble
11-28-2002 09:20 PM
Quick Reply: 223 3-speed to 300 3-speed swap
