A/C trouble 2010 lariat - Ford Truck Enthusiasts Forums
Old 05-15-2013, 09:12 PM
tonyjklh tonyjklh is offline
tonyjklh is starting off with a positive reputation.
well now that the weather is warming up ive found out my a/c doesnt work very well. the air is cool but far short of COLD. at first i thought it might be low on r134, but now i dont think so. i hooked up the gauges(high, and low). added about half a can of r134. but no differance. 80 degrees outside low side pressure 25, high side pressure 230-250. adding r134 didnt raise the low side at all, just the high side. low side pulls down to 25 and after about 20-30 seconds there the compressor shuts off and then cycles again.
it sounds to me like expansion valve but id like any other opinions. i bought the truck in february so i dont know whether the a/c worked last year or not.
also where is the expansion valve located at? its not under the hood.
thanks for any help
Old 05-15-2013, 09:43 PM
Going_Going_Gone Going_Going_Gone is offline
Going_Going_Gone is gaining momentum as a positive member of FTE.
My 2010 has had AC issues in hot weather from day one. The AC operation is tied into the PCM. Best fix for mine was a second PCM reflash (10-13-5) for cooling fan strategy. Still takes forever to cool down the cab, but the discharge air temperature decreased by five degrees after the reflash. As long as I don't have to ride in the back seat, I can live with it.
need ac help on this long roadtrip genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-04-2015 04:14 PM
1996 F350 7.3L AC Issue dennislarock 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-14-2015 08:14 AM
A/C problem Fixed on 5.4L in 20 Steps. runstang22 2004 - 2008 F150 2 08-08-2013 08:29 AM
70 Ranger XLT Factory Air Question 70_RangerXLT 1967 - 1972 F-100 & Larger F-Series Trucks 4 07-21-2010 03:33 PM
Orifice Tube on 89 Ranger 2.9 CobraSJP Cooling, Heating, Ventilation & A/C 5 07-02-2008 09:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
