Headlight removal...how????
I have a 2013 FX4 and I found the three screws holding the headlight fixture, I removed them and it was loose but I didn't want to pull to hard without being sure I should. Is that all that holds that assembly on? I know it's expenseive so I didn't want to pull to hard.
I'm trying to get to the running lights wires to add some running lights. I made a bar with some lights to put behind the grille. Is there somewhere else those wires are easy to get to?
I'm waiting for Helm to release the wiring manual for sale. Until then it's hard for me to find out what wires are doing what.
Here is a video I used when I installed my Silverstar Ultra's
Headlight Change 2009-2013 Ford F-150 - 2009 Ford F-150 XLT 5.4L V8 FlexFuel Crew Cab Pickup (4 Door)
Same here, I used the Phillips equavalent to Silverstars and there was no difference that I could notice. I ended up with some LED driving lights. Now THOSE helped!
Thanks for the help...I got the headlight out and installed a wire tapped off of the yellow/brown wire that goes to the running light. It only has 8.5VDC on it so it wouldn't trigger a 12V relay. I want to use a relay to not add much of a load to the existing circuit.
The research I've been doing is pointing towards using a 6V relay with an inline resistor to drop the voltage down. The relay has a 22 ohm coil so if I use about an 11 ohm 1 watt resistor I should end up with about 6V across the coil.
I'm going to look for some parts locally this weekend but I'll probably have to end up ordering them.
tjbeggs
22
06-03-2010 12:02 PM
BoomerPower
01-26-2005 10:05 AM
